I picked up an older or maybe old Sears Whole House fan on CL to help with my basement humidity problem. The unit works -- that's not the issue. Before I put it in the attic I'd like to lube it well, odds are it's not been done for some time. It has an Emerson motor and I found info on that, it needs 20w oil, and I see two rubber plugs on the ends which I think are for oil. The shaft of the fan has a spring loaded cover that I believe is for oil too, just not sure how much and what type. I'm thinking of using the same 20w oil I get for the motor.
The Sears model number is 758.63912, and it come up but the manual is NLA, and there is no info on Google that I can find. Can anyone hazard a guess as to it's age and oil needs?
