Opinion of vintage (late 70's?) Maytag Washer?
Try
soaking the lint filter in white vinegar.
It's usually very effective at removing the sort of build-up on lint filters and fabric softener dispensers. It's cheap and environmentally friendly and if it doesn't work, then you can try the next step of using a chemical.
After that, if you have one, run it through the dishwasher.
The spray power and detergent action will get into all those small holes and clean them very thoroughly.
I suggest CLR for that tub issue as well.
In fact, they show it in the commercials being used for just that purpose.
And if I'm not mistaken, the first ones years ago showed a Maytag washer with a white tub and rust marks.
Just my two cents worth, but hope it helps.
And good luck, that's a very nice machine you have a acquired there, and way better than your Shredmore any day!
I bought some Iron Out and ran a cycle with it, it definitely helped, but the buildup likely took almost 40 years to accumulate, so I don't expect it to disappear in 30 minutes or less. I just ordered new belts because it seems to struggle to agitate for a couple minutes if I haven't yet run a load, and I can slow the agitator down just by grabbing it. Can't complain, just over $9 for both belts, and they look super simple to replace. Othrwise, it's working great, and I'm very happy!
oh what have I gotten myself into??
I ran another cycle with Iron Out and hot water, then figured what better time to try removing the agitator? It came off with a pretty good effort, and I found even more hard water scale than the lint filter.. About 1/8" thick under the agitator and a nice crust on the bottom of the agitator itself! Luckily the crust on the tub came off with minimal effort, had to chisel a couple spots gently to get it to let loose and it came off in pieces, a couple 2-3" pieces were like concrete. The agitator wasn't so easy though, it's in the utility sink downstairs on it's third soaking with thick toilet bowl cleaner. Scrubbing with a stiff bristle brush between soakings and it's improving slowly. I can't imagine how hard water must have been to build up like this- when we moved into this house, there was a 1989 Speed Queen in the basement, and a 2001 or so Maytag Performa upstairs- Neither had any buildup to speak of.. A little orange staining where water fills, but no crust anywhere and I'd had the tub out of the Maytag and at one point the agitator out of the Speed Queen. I consider our water hard, but apparently it is nothing compared to what this poor machine was used in! Here is a picture of some of the crust I removed from the tub.. And that isn't all of it.
I was right, wasn't I Dustin? Now imagine what's between the basket and the tub. If you get that far it will be just as bad or worse. That's that old nasty water for ya.
Not going to dig that far into it, at least not right now, It's working great as it sits and no odors whatsoever so I don't see a reason to go any further. Almost have the agitator cleaned, just need to give the tub another good scrubbing and put the agitator back in. Will install the new belts when they come, supposed to be here friday.
Water Hardness
Well, a kettle in these parts can go bad within one year without cleaning. Water is 25gpg.
Dishwashers, washers, everything. The scale is hideously bad.
Belts are changed, took about 5 minutes :) Really made a difference in spin, clothes are coming out much dryer, but unfortunately it's wanting to dance a bit now. I think I just need to level it though. Surprisingly, the old belts looked to be in pretty good condition- just weren't doing the job properly.
for the lint filters, on just about any machine.....
use a power washer.....
if you don't have one, go to a car wash.....
just keep your foot on it otherwise it will go flying out of sight...
found this to be the easiest and fastest way to clean every nook and cranny....
