The 1010 Maytag A207
Wow, Fun progress
The noise you got on one of your spins was the top of the basket hitting the tub cover, it has always been difficult to get the basket lined up and centered on the basket mounting stem and the tub covered properly spaced and centered as well.
A major part of the problem is production tolerances weren't that good on the stamping and welding on the outer tub and wash baskets and they never intended these washers to spin this fast. I put a new center seal in a 1991 MT washer a few weeks ago and had a terrible time getting everything lined up to keep the basket from hitting the tub cover occasionally.
The problem is the basket flexes enough to hit the tub cover and if the heavy part of the load ends up on the side of the basket that is too close you may get some contact with the tub cover, but you might put the same unbalanced load in 10 times and never get the interference again however.
There is no effective adjustment to the crude out-of-balance-cutout on this washer, the OOBC is just intended to stop the machine as the spin starts if it is badly unbalanced, it will not stop a spin that is reaching full speed.
I dough the hot rubber smell is the brake, more likely the main drive belt, hopefully not the center seal.
John L.
Wow, Fun progress
John L.
