Opinions Needed on Souping-Up a 1970s Helical Drive Maytag
>> an extra advantage your having is no slipping clutch/belt from that setup....
>> again, souped up or not, something Maytag should have had all along...
Not sure I'd go that far! That slippage is an integral part of the Maytag design... Everything else around it is built with the assumption that that slip is there, so if Maytag were to have taken it out, they would have had to deal with the consequences in other places! It might have looked like an entirely different machine when they were finished...
Maytag Spiralator Agitation
Wow that's a huge improvement Robert, Very cool.
Good Point Martin getting the performance robbing slippage out of a MT DC washer is a big plus.
Its funny that when MT introduced the helical drive washers they had a belt tension system for the main drive belt that allowed no slippage at all during agitation and then when the motor reversed for spin it would slip nicely as the water drained and the basket got up to speed.
Then around 1960 they ruined the belt tension system with the introduction of the motor carriage with the plastic rollers which allowed too much slippage during agitation with big loads or in cold rooms dooming owners to poor performance for over 30 years.
No other AWs drive system ever built allowed slippage during a washers agitation.
Finally in the last decade of MT HD washers Maytag mostly fixed this problem by moving the tension springs in the motor carriage to the same side which really helped the sluggish agitation issues that us service guys had to deal with.
John L.
Easy agitator
Is this agitator out of an automatic or spindrier ? I don't know if the agitators were different but the spindrier tub was HUGE.
Well the machine has an digital clutch now, so if the transmission ever locked up it would immediately cut power to the motor. From what I remember with the 806 I had for several years the agitator never slipped unless the basement was super cold and only for a few minutes of the first load so I don't remember that being much of an issue. However I do believe this will end the issue of winter basement sluggishness, but will we see in six months.
This is a Spiralator out of an Easy Automatic, not an Easy spin-drier but I don't know if they were the same agitator. The big difference I see between the two agitators is the Easy gets all the clothes down faster into and under the water, however that doesn't mean it really makes much of cleaning difference over the Maytag, its just the action is a bit more dramatic.
Soooo onto a different subject lol. That big load of towels you saw in that video I was curious about something. So I washed them in hot wash/cold rinse in the Maytag which spun them at 1050rpm. Then I re-rinsed them in cold water as well in the '58 Frigidaire Unimatic with 1140rpm spin as a test. But after each test I weighed the entire load zeroing the scale with an empty basket. So here is what happened.
First empty basket and zeroed scale...
Next the towels dry before washing weighed
I'll save the Maytag for last. Now the towels rinsed and spun in the Unimatic at 1140rpm for 4 minutes (3:30 at full speed)...
and now the Maytag wash/rinsed and spun for 5.5 minutes (4:15 at full speed) at 1050rpm, what have I done! I've created a monster lol
This also means 1050rpm is the winner and really no need to take the machine any higher in speed at this point. I noticed the other day that a big load I had done the dryer had finished and I thought wow that was fast, but I figured I was just imagining the timing, that couldn't be right. I guess it was right after all.
Better Extraction due to the Perforated Tub as to Solid Tub ?
I'm not exactly sure but that would be my first guess that it's easier for water to escape from the clothes in a perforated tub. I suspect that faster the tub spins the more that makes a difference as well. Could be the specific shape of the Maytag tub as well as it's diameter. Next week I'll do the same test and compare it to the '47 General Electric which has the best extraction of any 20th century washer.
One more major change to this machine and it will be ready to leave the workshop and get installed with the other machines. Hopefully that will be by the end of the weekend. Pictures to come.
I'm also thinking of adding another toggle switch to force warm rinse as this machine doesn't have a warm/warm setting which I use all winter long.
What was the spin time ....
for each machine? Looks like the MT spun a minute or more longer.
How about spinning both for the exact same time and then tell us? Maybe 3.5 mins at full speed per machine. That would answer the solid tub vs perf tub question since the rpm's are the same now.
How much of a diameter difference is there between the two?
That alone could easily advantage one machine over the other...
What a VAST
Improvement over a regular Maytag The clothes actually do something instead of just sit on top as they do in a normal Maytag with anything but a very light load!As John so correctly said load them up like you can a Kenmore or Norge and the belt slippage prevents any decent washing action.
My past experience matches Robert's.  The only time the belt slips during agitation on my 1972 Maytag A606 is when it's cold in the winter, and then only for the first minute or two.  Once it's warmed up, it will stroke away at 63 O.P.M. all day long, even with a load of Carhartt cargo pants.
Robert: Soup up that machine all you wanna!
Yes,it's your machine, but everyone claims it as "their's"? I don't think so...
Add all those modifications anywhere you please, like that Sapphire Whirlpool (was that (done by) you?) you have got every damn right!
Me, my reaction, as long as the machine is in every norm of perfectly optimal working orde has been anything but this:
By the way, while the new agitator fits this Maytag to a "T" what do you do about lint?! (Yes, the native lint filter's gone, so is there now NONE?)
-- Dave
So it turns out the Frigidaire Unimatic tub is 22" in diameter and the Maytag tub is 21" in diameter. That means the increased spin time as well as the perforations in the Maytag tub make for slightly better extraction at 1000+ rpms, or at least we can make that as an educated guess.
Actually the Easy agitator does have a filter. I'm more concerned with a fabric softener dispenser as I don't have one that will fit the Easy agitator.[this post was last edited: 7/26/2019-09:01]
technically, lint filters have been removed from machines long ago....
if Robert wanted to, he could switch out the inner tub with one that has the so called self-clean filters under the agitator...
although they did catch lint, there was still a fair amount left in the tub/load...take any machine with a lint filter, and at the drain portion, place a screen colander under the drain hose, you will still find a good amount of lint left behind...
I rarely, if ever, use my lint filters in any machine I have....
if you sort properly, correct wash time/temp, and detergent amount....the lint should be held in suspension until the draining...
a few times on Kenmore/Whirlpool machines I had to bypass the self clean filter....in the long run, you wouldn't know it was even gone...
odd too....if you ever used a wringer washer, and washed a load of towels, you would see lint floats...hence why overflow rinses were so effective....
although, we love the drama of the waterfall lint filter systems....
very nice, and colorful choices....impressive!
of course this will be the first time a Maytag will splash water at you with a Speed Queen agitator.....
I vote for a video of that with different water levels and speeds...
now you got me thinking of a new way to try out agitators in a Maytag....
That's assuming that "lint" is the only thing you're intending to catch!
The Maytag agitator filter works brilliantly for pet bedding and other loads with hair, fur, or other debris. Some loads I'll clean the filter three times because it is fully packed, flush to the agitator wall.
Not saying it's the best filter design (it's not), but for our wash loads, there's no way I'd run without it. It's surprisingly effective at removing debris from the wash water. The biggest flaw is that it isn't any larger!
Too bad it's not possible to replace the lint filtering material in Maytag's screen filters...can't wait to see the Coronado and Speed Queen agitator's in action
Easy filter
The filter is pretty useless. It depends on the water being pushed up the fin of the agitator with the forward stroke. If the water level isn't right it won't work. Even when it does work there is not much water pushed into the filter pan
Lint Filters In AWs
The most effective lint filters in top loading washer were the WP-KM models in the late 50s-mid 60s that had a metal screen that you cleaned, also about as good were the first GE FF models with the metal filter pan and of corse the WP-KM belt drive machines that had a separate self-cleaning filter that's back washed when draining by the water pump. After these examples no other brand or machine came close in overall effectiveness.
When our family switched from a TL solid tub 1960 Franklin built washer [ with a useless agitator mounted lint filter and overflow rinse ] to a 59 LKM with a self-cleaning filter my Mom and I could not believe the difference, we thought the lint filter in the dryer had stopped working as there was less than 1/2 as much lint in the dryers filter load after load.
Overflow rinsing in a ST machine is good at getting rid of floating scum but not that great at rinsing detergent or lint away because lint stays very evenly dispersed in water as long as the agitation is going. Also lint does not float, take a mason jar fill it with water and some dryer lint, shake and and a day later the lint will all be at the bottom of the jar.
John L.
Robert
Can you use an older Neptune motor? Not sure how complicated they are. Or the motor you use is more simple.
Ps I’d love to see this in person, I live in Des Moines and go to Minneapolis couple times a year.
I agree about the Easy lint filter, it's not very effective and the water level has to be just right for it to work very well at all. But I also agree with Yogi, with everything going in the dryer a lint filter generally isn't necessary. The exception to that in my opinion is washing things with pet hair. That I like to use the solid-tub Filter-Flo for as it is by far easiest to clean with a lot of lint.
I'll get working on more videos next week, right now I'm working on another major update to the machine. I tried the Franklin angel wing agitator yesterday and I was not too impressed with the results. The Maytag and Easy agitators are much better, but I'll try it again with a different kind of wash load and see.
Let me know ahead of time that you're coming Tom and I can give you a tour of my machines and the new Maytag, or maybe as I called it the other day the Mayszy!
More to come soon.
Stopped by Robert's yesterday on another mission and got to see this egineering marvel.
It's really kind of nuts. It looks like a Maytag, but it doesn't sound or act like a Maytag!
The suspension clearly holds up to the increased rpms of the spin. It's pretty much silent.
And the test load that we run was Unimatic dry.
