Eggstacy!
Well, I don't think I'm going to have to bother with my complicated egg blanching multiple pot routine any more.
Tonite I picked up an "Aroma" brand egg cooker at Target. All of $19.99. I just got through cooking an initial batch of four large brown eggs.
I'm delighted with the results. Alhtough these are relatively fresh eggs, they came out very easy to peel, but without a rubbery layer on the outside. They were basically done exactly (eggsactly?) as I wanted, maybe a little on the soft side, but then I ate one while it was still warm, not waiting until it cooled completely.
The Aroma looks similar to the Cuisinart, with a egg shaped highly polished stainless dome lid. It buzzes when it's done, which I think is a good thing, as the eggs will continue to cook even with the heat off, and at that point it's time to turn the thing off and plunge them into cold water to stop the cooking. The manual says you can leave it on if you want to keep the eggs warm; I don't know if it continues at full power or switches to a lower power heating element at that point.
Four hard boiled eggs took about 15 minutes. Not bad.
The cons: The egg piercer on the bottom of the water measuring cup is too thick and tends to crack the egg shell. But I have another egg piercer, part of a combination egg slicer/piercer, and it works just fine.
The water markings on the measuring cup are a bit mysterious. They are clearly marked, and the photo in the manual matches them. But I'm puzzled as to why cooking just one hard boiled egg takes less water than cooking seven. Intuitively I'd think it takes more water to cook seven than one... so I'm thinking the markings are erroneous, in a reversed order. Especially since the markings show that it takes more water to cook hard boiled vs. soft boiled eggs, of any number. Hence the decision to cook a middling amount of four. I'll try cooking just one, and then seven, using the markings, to see if I need to reverse the markings. Hey, what do you expect for 20 bucks? LOL.
I'll try to post a photo of the Aroma egg cooker in a few days.
Also, while at Target, I picked up a Thomas O'Brien "Vintage Modern" retro wall clock. It's quite appliancy, with deco raised chrome numerals on a white enamel ring on a chromed metal surround. The numerals look like they're off a 30's or 40's fridge or stove. Not cheap at $30, but it looked so nice I couldn't resist. I'll post a photo of that soon enough as well.
Here's a photo of the Aroma egg cooker off the Target website. It looks a bit better in real life:
