henene4
Yesterday our old flat-share washer died, so I had to wrangle with draining it, shipping the soapy soaking wet to friends place to get it rinsed and getting in contact with our landlord.
Probably the PCB; the machine stopped mid-mainwash with the door unlocked.
Wouldn't lock again; however the PCB wasn't even putting put any voltage to the door lock.
First my landlord wanted to get it checked out, but then he decided to just give me the go-ahead to buy a new one.
The old one was a Gorenje W6543/S.
Slim-line machine with tiny drum (6kg rating, 42l) and a normal motor, 1400rpm.
It was a decent enough performer.
It always filled with quite some water (it usually filled 1/3rd up the door or higher, however that was just about 15l due to the tiny drum) so saturation was never a problem and rinsing was usually decent.
Rinsing suffered from a often less then stellar interim spinning performance which caused the suds lock protection to trigger thus canceling the interim spin.
(Fun fact: It had 2 pressurse switches, one fixed level one and one variable - probs analog - level one. The variable one checked fills, the fixed level one triggered for overflows and suds-locks.)
Plenty of wash cycles and plenty of options and - if you selected the "Allergy" option - 40min of temperature held main wash and 4 verry deep rinses.
Cycle tinmes were somewhat long though and spinning often took ages.
My landlord wanted a washer with A spin performance and our local MediaMarkt only had 2 models at an acceptable price.
One was a Beko, that however didn't have a rinse option independet of a prewash and a smaller drum.
So I got one of the new WaveActive washers.
Model is an W2A866T.
8kg drum (though that is more then optimistic at 54l), A+++ -20% rating, 1600rpm, inverter motor and a 2-step Water+ facility.
Got it for just below 390€.
My flatmate helped me move out the old one and just helped me move in the new one.
Pictures and reports will follow once I set it up (which will be chore due to the anything but even floors).
