P-7 Light bulbs?
sarahperdue
Gold Member
Nov 7, 2009
1,108
Alabama
Some of you may remember that Kelly helped me score a gorgeous never installed P-7 double oven on Craig's list a year or two ago. It's my first self-cleaner, and I love it. The problem is that every time I use the self-cleaning cycle, the light bulb burns out. Do I need a special light bulb to withstand the heat of the self cleaning oven?
Thanks,
Sarah
I'm not positive
But I think they are just the standard appliance 40W bulb. The one thing to remember is to make sure the light is off during the self-clean cycle and that the oven has cooled before you turn it on, otherwise the filament can't stand the high temps and will blow out.
Newer GE ranges uses a Halogen type bulb, but I am pretty sure the older models didn't use anything special.
Sarah, there are special 'appliance' light bulbs for ovens and refrigerators. Check in the electrical section of a hardware store - they should be there.
Hope this helps!
Sarah,
there is a special "dilectric" grease that you can put on the threads of the bulb. Sometimes the heat will make it almost impossible to unscrew the bulb. I know someone on here can give you advice on what it's called.
ps: If the bulb won't move at all Don't force it! Ask me how I know.
In our P-7 we had at our last house we used a standard Appliance/Oven 40W bulb. Never had a blowout/burnout. Those P-7's really hold a steady temp. it's our favorite oven. We wish we had room for one of those here.
Never had a problem with my P-7 oven and light bulbs, either. I upped the wattage to 60W in order to try to get a good temp for making yogurt, but eventually got a separate yogurt maker instead. The 60w bulb is still in there, though, and seems to be withstanding the occasional cleaning cycle just fine.
At least here you can get two types of lamps for ovens, in different wattages (25, 40, 60, 75, 100W) that withstand 300°C (for non pyrolitic ones) and 500°C versions (for pyrolitic ones).
They cost just a couple € more than a standard CFL light bulb.
I used one of those to replace a defective sauna lamp that burned out every three months...
Ours burned out once after the self-clean cycle, but I'm pretty sure it was the original bulb (from 1990!) It has been over a year with the new bulb (and several cleaning cycles) and it is still fine. I did use a "long lasting" appliance bulb, just because it was a major pain to replace.
Do you have the thick glass, cup-like shield in place, over the bulb opening? And is it aligned and tight?
This protects the bulb, and the rest of the oven from the excess heat.
