Qustion before I screw it up......
Maytag Neptune MAH5500BWW FL series 73938170ZU.....just like the spare one I got off you....
the machine still works...but I am having an issue with the cycles increasing time over the period of about 2 weeks.....Cotton Sturdy, Normal soil, used to be 52 minutes....little by little the time has increased, now its at 83 minutes.....although it will perform as usual, but close to 1 1/2 hours to wash a regular load......reminder I have several that work in unison "the FLEET"....start them all at the same time, and they all end at the same time....except this one
but my question really is, I want to switch out the main board up top, or should I change out both, top and motor controller.......I have both....but don't want to transfer an issue with one, into the replacement, and mess it up again......
I know on the 3000/4000 series the motor controller instructs the timer when to advance......and curious if the motor board is really my issue......
other wise the machine runs fine, just extended wash, rinse, spin times.........almost like if I selected "stain cycle"........but adding any other selection, extra rinse, stain cycle, pre-soak---puts the time up to 99 minutes or more......
I have unplugged the unit for a few days.....but nothing changes.....same cycle, same soil, 83 minutes....
Thanks in advance
Thanks in advance
