Pale blue Kenmore 70 Dryer, 1963
akronman
Jul 20, 2010
2,258
Akron/Cleveland Ohio
I picked this up yesterday from the same couple who last week sold me a 73 Speed Queen washer.
This is Kenmore 70, Electric, pale blue, Model #110.6308740, ser 01890M423. When they bouhgt the house last fall, this was plugged in and running right next to my washer.
It has a flourescent light only for the dials, not full length. It has a Air Freshener scent bottle, and is labeled Soft Heat and High Speed.
more
controls. Only high heat or air dry, no Perma-Press or low. And only timed dry, no timer-versus-heat. Picture ain't great, but it has 100 minutes. Seems a bit strange that it has lights and a scent bottle(both high-end) but only timed heat and only one temp(low end)
wiring
The diagram shows it's the double element "Soft Heat" with a 2000 and 3400 watt elements, a drum light, no buzzer or bell. 5 minute cool down is a regular cycle only, not any aspect of PermaPress.
label
I like this little bit of advice. Also, to my bad eyes, this pic shows the color the most accurately. Anyone know what Sears called this back in 63?
lint
The lint filter matches my 59/60 also, and needs new heavy felt and rivets. These 2 dryers need a tight fit on that felt or the top of the machine gets hot and the lint goes all inside. This area is pretty ugly, the rest of her looks fine.
Seems weird that my earlier model is Auto-Dry and 2 temp PermaPress, but no lights or scent, while this model is prettier/more upscale presentation, but single temp and no Perma Press, and timed only. But it has dashboard lights! I soon have to say no to more electric driers, I hate the bills.
Beautiful dryer! Congratulations!
Don't let the simplicity throw you. The Soft Heat maintained a relatively safe temperature for everyting, PROVIDED YOU DID NOT SET THE TIMER TO ALLOW OVERDRYING of delicate fabrics. It was much faster for the reasons I posted elsewhere and was designed so that as the load got closer to the cycle end the smaller element would be on giving lower heat input because the load would be dry and less heat was needed to maintain the drying temperature.
If you want to make it more efficient, you can pull the drum and put a strip of felt around the air inlet and around the exhaust port. Those pieces of felt will lessen the amount of heated air that will travel behind the drum and go directly from the inlet to the exhaust
efficiency
Tom-----I have a 65 or 66 Lady K Soft Heat, single temp. I know how the 2 elements cycle and yes it's quick and effective. When I tear into this for de-linting and motor and bearing oiling, I will carefully check the felt and replace. And I can also re-felt the lint filter for both this and the 1960 model at the same time, Graingers sells felt in many thicknesses and widths.
This is quite the hybrid mechanically between the 66 and the 60 in many way. 60 has the A-frame supported bulkhead with the spindle-supported drum. This uses the sheet metal full cabinet bulkhead but still has the spindle assembly. The 66 is entirely supported on the rear bulkhead and front door, no spindle. And the 60 is still the bowed front design, where this is the squared off front like the 66.
1963 Electric Kenmore 70 Dryer
Our family bought this dryer new in 1963 to replace the troublesome 1957 WH Space-Mate dryer we had since 1957. The KM was a much better built dryer that never gave any problems till I replaced it in 1971, but the amazing thing was that the KM took at least 15 minutes longer to dry the same loads from the same automatic washer than the WH SM which only had a 4,800 watt element compared to the KMs 5,600 watt element.
Mark, when you get around to rebuilding this dryer contact me and I will describe how Tom and I added an additional seal to the bulkhead that makes these inefficient slow dryers a little faster and more efficient.
I have a Gas Coppertone dryer like this for sale if anyone wants it, the gas ones were very fast with a 37,000 BTU variable input gas burner, and you can also add the extra felt seals to the gas ones and have a really fast dryer.
Felt seals
John---Thanks! I will be very interested in that, and hopefully will also be able to tighten up the airflow on both the 1960 model and 66 with your advice. I prefer gas, but at the age of these machines, I can't always choose what I can find locally. Let's get through the holidays and then I'll have a January project. I think I'll also temporarily retire the 62 Frigidaire dryer, and have a 60, 63, and 66 Kenmore electrics in a row.
When I was a kid
We had that washer and matching dryer in white. I barely remember them - they were replaced when I was about 5 years old. That is the laundry pair I would like to have more than anything else.
Mrs. Meier two doors down had this dryer in gas/coppertone matching her coppertone washer; my mom had the identical washer but a couple years newer electric dryer. She got at least 15 years out of it (4 kids) ..my mom got about 25 years out of hers (she hung underwear and flat sheets to dry; and just 2 kids).
My mother had this dryer in gas too as well as the washer
the dryer lasted from 1963 to 1979 and the washer lasted till 1989 the last 16 years being at our summer cottage…PAT COFFEY
1963 model 70 set
They must have made this model for a couple of years as my aunt and uncle had this set in white from 1965 (bought new) until about 1980 for the washer and late in the '80s for the dryer.  I always liked this set and it was one of the main reasons why I took on an interest in washers and dryers.
lint
that's the underside of the lint door, with the holder for the bottle of scent. Knowing my 60 Kenmore dryer, I think this is one spot to add a gasket, or the blower shoots air into the underside of the cabinet top. If it works for this, it will soon be time to go back to "upgrade" the 1960
of course.....
the motor is dirty as hell. Also, the blower belt is round, I haven't seen that since my Hoover #519. Belt is currently off, but you can see its pulley. The Speed Queen washer this came with was vastly cleaner and recently serviced with a new pump and belts and hoses. Maybe the drier gave no problems so wasn't opened up IN 50 YEARS!!!!
