danemodsandy
I could use some trim parts for the J757 I recently acquired, and there are a couple of contemporaneous models that use parts in common with this model.
If anyone is parting out a range answering to the descriptions and photos below, I would be damned grateful to hear of parts availability! Here goes....
I could use the oven door and handle assembly from a WHITE J797L Americana. This model uses the same oven door as the J757. Other Americanas do not. I actually only need the outer door skin and handle, not the entire door nor the glass pack/shield assembly. And gotta be White, sorry to say. I say "sorry" because that is the least common color on Americanas, so far as my own experience and observation goes.
I could also use various cooktop and backguard trim parts from a J856 Versatronic. Color does not matter here; all the parts needed are bright-metal parts. Sadly, I cannot use the backguard glass; the Versatronic's control panel is quite different to that of a J757, mainly due to the lack of the electric meat thermometer. I might also be able to use the clock, though.
The Versatronic parts would be the most immediately helpful, and hopefully the easiest to find, since some critical Versatronic parts are NLA, forcing some scrapping of these units.
Photos are below. Any and all help is appreciated!
