PARTS - Various Parts For Sale
macboy91si
Jan 10, 2009
1,296
Frankfort, KY
I'm moving, and a lot of parts need to go. I've parted several machines out and I could stand to get rid of them.
my e-mail is [email protected] if anyone is interested, these parts will fit a few other models as well. You can pick them up or pay for shipping if you like. They have been tested to work.
-Tim
Kenmore Dryer
1st up: Late 80's BOL/MOL Kenmore dryer, model: 110.96272100
I got this one from a friend, the motor was failing and he bought a new unit. The heating element works, and so does the timer and sensors. I did not end up repairing it, which I may regret later asit was a nice hamper door dryer.
I have the following parts from this machine:
*Leveling Legs
*Sensors
*T-stats
*Heating Element Assm.
*Entire Control Panel w/ Timer
*Belt/Idler
Maytag Atlantis Washer
Early 00's Maytag Atlantis washer, model MAV6601AWW
I picked this machine up from the local high school, the transmission was having problems and it wasn't worth fixing. It's a pretty well optioned model and was cosmetically in good shape. It spun and pumped good and the washer activated in all of the cycles, but the washer would not agitate and made a horrible metallic grinding when trying to do so.
*Lid Switch
*Agitator
*Motor w/Pulley
*Pump
*Belt
*Entire Control Panel Assm. w/Timer and Switches
*Inlet Valve
RCA/GE Washer
I don't have any pics of these parts yet.
Late 90's RCA/GE Washer, model number unknown.
I picked this machine up from a friend when I sold them a newer GE. This machine was horrid, the timer went out and it sat with water in it for nearly a month. Mechanically, there was nothing wrong with it, it agitated and spun and drained with a good timer. It was just so foul that I didn't have the time to properly clean it up for sale again. That and the PO had tried to get it apart on their own. I salvaged a few good working parts.
*Newer Style GE 2-Speed Motor/Clutch/Pulley
*Drain Pump
*Drive Belt
*Leveling Legs
*Water Lever (L/M/H) and Temp (C/W/H) Controls
*Suspension Rods
*Base Model 1 PC Agitator w/No FS Disp.
Kenmore Elite Washer
Again no pics of this one, sorry
2004 Kenmore Elite, model number unknown
This WAS a nice machine. It stopped spinning and the PO bought a WP Duet. I was going to repair this machine, but it's too complicated for my tastes. It's one of the giant lid models with the under-lid plumbed dispenser systems for everything. The inlet valve was scary as it had 4 or so outlets on for the various dispensers. The machine would run in spin mode, and neutral drain, but the the motor would change pitch a bit and nothing would happen. You could manually spin the tub and it would try, but wouldn't keep spinning on its own. I think the clutch or brake was the culprit and I'm not THAT familiar with WP DD machines. Also one of the agitator fins were broken.
*Dispenser System and Inlet Valves
*Control Panel Assembly w/Control Board
*3 Speed DD Motor
*Tub to Pump Hose w/Clamps
Hamper door hinges
If it's not too late, I have a friend with a Kenmore dryer with bad door hinges. If you could get the hinges and springs that go with them, I could patch that up for her.
Should have posted 1st
I've already scrapped the machines unfortunately so all I have left are the boxes of parts listed. I really should have posted before hand, but I have no space to keep things right now as I'm moving and things are just a mess here :( I scrapped the front panel with the dryer. They sagged a bit and were going to need attention, I didn't think they were worth having so I didn't mess with them.
Sorry
-Tim
