I have one of those polyester fiber-filled body pillows about 5 ft long. Even though I keep it in a case I thought it was due for a washing. I knew it would not fit in any of my front loaders and trying to get it submerged in a top loader would not be fun so I borrowed some modern technology to wash it in my A806. I put the pillow in the machine where it almost fitted the circumference of the tub. I added liquid detergent and filled the tub to the minimum level. Just when it started to agitate, I stopped it. I put an extension on the drain hose and held it over the tub then turned the dial to the drain after wash and restarted it on slow spin. This nicely sprayed water on the pillow while the spinning tub forced water through it. After a couple of minutes, I stopped the washer and let the pillow soak. After 10 minutes, I repeated this. I moved the timer to the final spin at 757 rpm speed. As the wash water sun out, I used a hose with one of those big round garden diffusers that make a gentle rain to spin spray the pillow for about three minutes then reset the timer for the spin after the wash. I filled it to medium for the deep rinse, but did not let it agitate, just dunked it repeatedly and let it soak for a few minutes before the final spin. Drying took much longer, about an hour with position changes every 20 minutes, but the pillow is clean and undamaged by agitation.
