Plumbers putty vs silicone sealant kitchen sink
dermacie
Nov 25, 2014
498
my forever home (Glenshaw, PA)
I recently (9months) ago had my kitchen professionally remodeled. I picked a single bowl stainless steel sink to be installed good quality. I noticed about two months ago a slight drip coming from the basket strainer under the sink only when the sink is full of water. I tightened under there and it seemed to go away( I check it often).
I noticed that it is back and I am wondering if it is because the installer used plumber’s putty on the strainer. My father who has since passed built this house and I am positive that he used silicone sealant around the basket strainer in the past and I am wondering if I should take it apart and use that instead?
I used plumbers putty when I put the drains into all of our sinks, never had a leak yet.  As long as you use enough for it to squeeze out from the edges of the drain flange when its tightened down you shouldn’t have any leaks.  I have used silicone on some of the faucet mounting plates, I don’t think its any better than plumbers putty though.
Eddie
Putty
<span style="font-family: helvetica;">I remember a few years ago I was having a faucet put in and the plumber really loaded up the putty.  After he tightened it he cleaned up what oozed out.  He said, we want it to ooz out because that's when you know you won't have a leak.</span>
Why not do away with both,
And just use a flat rubber seal in between the bowl of the sink and the flange of the fitting? It works wonderfully over here and nobody has had any leaks whatsoever since installation
Check the the strainer flange for any damage or defects and reseal with plumbers putty. Tighten the nut firmly but don't over torque.
Silicone sealant would be a nightmare to clean up next time the sink needs the strainer removed.
