I tried a google search on this but couldn't find anything; maybe I wasn't using the right search terms. The washer drain needed to be snaked, as it was overflowing at the top of the white PVC pipe. I wasn't getting anywhere running the snake from the top of the PVC pipe, so I decided to remove it.
The pipe just "fits" into the iron floor drain, as in the photo. However, it wasn't coming out by hand, so I used a pipe wrench to turn it back and forth to get it loose. That worked fine, and the snaking was successful.
However, now that I've put it back together, I'm getting a little water coming out where the PVC pipe goes into the iron opening. I can probably get the PVC pipe a little tighter into the opening by tapping on the PVC pipe from above, by placing a wood block on top and then tapping it with a hammer.
My question: should I do something else, like place a bead of plumber's putty around the PVC pipe, maybe around the bottom opening? It's a fairly tight fit along the sides of the pipe, so I don't think anything will work there.
I don't know what is "normal" for this type of drain setup. Thanks in advance!
