Bob, the ad description of Super Wash is missing the full details.
AldSpinBoy posted pages from the user manual back in 2009. Super Wash can be used as a stand-alone prewash, or coupled with apparently any full cycle. The instructions
do not say that it works only with the four Cottons-Linens (Normal cycle) choices but it's possible that is the case and the sequence just doesn't run with other cycles.
For stand-alone prewash, select Warm or Cold Super Wash directly. 6 mins cold wash, drain, spin, off. 4 mins warm wash, drain, spin, off. No rinse occurs, although Kenmore71 also posted info from a tech document that says there are sprays in the spin.
With a full cycle, select the cycle first, then select the desired Super Wash. It runs the Super Wash sequence (presumably the same wash, drain, spin), then proceeds into the selected full cycle.
The reference to Warm rinse in the ad presumably is when Super Wash is run with any of the Cotton-Linens cycles.
Kenmore71 also posted this timer/cycle sequence chart.
