POD 14-May-06 McClary 700 Set in Harvest Gold
Re: More Like:
GE/Hotpoint like the "POD's" Pix the Day before, I forget those Machines Brand, but they I believe were Canadian-Made for Machines.
Peace and Happy Laundry Times, Steve
SactoTeddyBear...
One of my favorite PODs...I wonder what the design of these machines were? The lid is very Norge-like, so I wouldn't think it would be a WCI machine, especially since it uses the Spiralator instead of the Westinghouse ramp agitator or WCI angel-wing. And we can factor GE out for obvious reasons, namely that the machine would be a definite clothes shredder if that Spiralator was to agitate at 100 OPM!
I guess it's one of those mysteries that will be solved when someone finds one! Does anyone think it's a modified Easy design, or even better still, a Velva-Power direct-drive machine?
--Austin
We had a 1962 "McClary-Easy, Proudly Canadian" (those days are gone) stove most of my childhood - really cool chrome script with the automatic senso-therm element that never worked. I have a McClary washer now from around '80 - it sounds like a lawnmower but it keeps on going!
Paging Unimatic
can we compare the agitator in this machine to the Easy's? looks same. and if THIS agi was going at 100 opm, not only would you have shredded clothes, youd have a tsunami!
Roger's TOL Easy Spindrier was fun to play with, especially with Nate's agitator in it. MUCH better action with that wide-base, extended-fin Spiralator; the clothes moved around the tub in a circle as well as rolled over extraordinarily! It also made a fun "KER-SLOSH" sound with each stroke.
As for the original aluminum agitator...well, let's just say that anemic is an understatement. We washed the exact same load with both agitators, and there was rollover, but it wasn't anywhere near as dramatic as the other one. It probably couldn't handle as large a load as the white Spiralator either.
--Austin
I'd bet that this was a Canada mfg machine (maybe from an older US design i.e. Easy) that isn't strictly comparable to anything available in the US in the mid-70s.
In the late 80s there was a big rationalization of the N. American appliance manufacturing, with Canada ending up with a dryer plant (CAMCO), a refrigerator plant (Woods) and one or two stove plants (Electrolux in Quebec, and maybe a CAMCO plant which makes the electric stoves with stacked controls on the back-splash).
Before that point, I think there was more individuality in the designs including spiralators :)
JL
Oy!
Sure is a handsome machine. It makes me think it is an Easy design, especially with the (I assume) trademarked "Spiralator" brand, which is imprinted on the bottom of Roger's Easy's agitator.
I wonder if it is Velva-Power? That'd be fantastic. I bet it kicked some serious butt when it washed!
Hey everyone,
I emailed John (pushtorelease) off the site for more info about his 1980 McClary-Easy machine and he gave me a lot of interesting information on it that is just too good not to post...sounds like a very fun machine to say the least!!
Here's some of what he said (omitted parts symbolized by "...") about the machine:
"...Amazing amount of noise...It looks a lot like the one in the pic of the day, sans the push buttons. Maybe it's just a more basic model? One cycle, one speed - a timer dial, a water level selector and of course the bleach cup but wood grain all the way across - very impressive...I had the back off it...there was no sign of a belt...I'm guessing it's a direct drive. The agitation is comparable to Roberts Easy, it really goes and it's not something I'd ever think about putting anything delicate in - I've got a Simplicity wringer that's a lot more gentle.
It's interesting when it starts the cycle - once the water has stopped filling, it pauses for maybe 15 seconds then the agitator starts but the tub moves with it, kind of stirring things up. After a few seconds, there's a clunk and the tub locks into place. Is that something that is fairly common? I'd never seen that before. <font color=black>(Sounds a lot like a GE; I wonder if the tranny had been modified to incorporate a faster tub brake by this time?--AW)
The other kooky thing is if you start it at the beginning of the cycle, you get hot water only. The people I bought it from had the hot water inlet hooked to the laundry tub tap so they could adjust the water temp manually. I found that if you turn the dial to around 12 minutes or so, you hear a different sort of click and you get warm. Voila! No where on the dial is that marked in any way. Maybe it was in the original instructions? Absolutely no choice of a cold wash unless you turn the hot tap off but the rinse is cold only, again no choice."</font>
Thanks again John for the excellent info!
--Austin
