Makes perfect sense. But to be honest its more out of missing what I had. Those world washers were better than DDs in almost all respects. They were gentler, cleaned better, rinsed really well and never suds locked, no matter how hard you tried. I remember using one to avoid the dreaded GE top loader I had in my apartment a decade back, and while I thought at first I made a mistake buying it (I was really skeptical and was convinced it would be only a hair better) it actually turned out far better than I expected it to be. To be honest I ended up liking that little washer more than my previous DD. It was a Kenmore which even came with a Hand-wash cycle. Only down fall was the machine would do a 180 after every spin cycle came to an end, but latter models took care of that by running the pump (and in turn splutch break solenoid) after the drive motor shut off letting the tub coast to a stop. I miss the little critter. A seal leak did it in (it was used) and the latter version I ended up giving away when I moved and acquired a full size belt drive Kenmore.
