Portable Washing Machine
retromania
Feb 17, 2011
1,140
Anderson, South Carolina
Anybody on here that uses a potable washing machine or has used one for a length of time, would you please email me. I need to ask you some questions. Here's the deal. I am painting my kitchen in preparation for bringing in a new/old stove. With everything out of the kitchen I was thinking how great it would be to get the washer/stack unit out of the kitchen. Ruins the whole look of things and I need the space in my small kitchen. I realize it would be a bit of a paradigm shift so to speak. I have a small storage closet in the kitchen (not big enough for stack unit) that a portable washer would fit in when not in use. Sure would be nice to have that space. Please anyone e me or share your thoughts. No where to move the stack unit. My neighbor who lives in the other half this 1941 duplex has the same problem. She's thinking about moving her washer/dryer stack unit to the upstairs. I don't want to do that. What if a hose popped. I might not hear the water (I'm about deaf) until I see it dripping from the ceiling. Also, what would the vibration of a washer upstairs do to old plastered ceilings downstairs? Comment anyone.
Our Kitchen Is On The Tiny Side As Well
Thus both the Hoover TT and the Whirlpool portable were stored elsewhere then rolled into place when needed.
If you get the extra long fill and drain hoses you can really keep the washer far from the sink in case things are "tight". When not in use after being left open for awhile to air dry, put a tablecloth or something over the units and voila, you have a nice table or space to set things on.
Only thing is to make sure the casters on your washer are in good shape. You don't want to mark up the floor each time you shift them about.
L.
Washer Placement
You left out what king of stack you have now but I would most likely move it upstairs. I agree with you that having your laundry in the kitchen is far from ideal, something like a 24" WP TT takes up little floor space and produces almost no vibration that transfers into the floor. For any upper floor installation of a washer where there is concern about possible water damage from a leak you should have a proper pan built and installed that connects to a drain pipe. The drain pipe does not necessarily have to go into the houses drain but it must at least go outside.
One  of my customers just had the PVC drain pipe coming through the wall on the 2nd floor above her deck, once when she actually had a leak she knew it immediately, if it had been plumbed into the sewer she may have not realized the washer had a problem nearly as soon.
I have a Bosch Axxis compact washer and dryer that stack. It would be GREAT if it could be moved to the upstairs with no concerns. Thanks for your comments. Especially about the tray and pipe to the outside. Oh. The dryer is a ductless dryer. I puts off a lot of heat. It would have to go next to a window as there are no bathroom exhaust fans. That's the other deal. Also, it cost a pretty penny and it's only about five years old. No problems. It won't spin if it's off-ballance, but sometimes it jiggles a lot when it starts to spin. Wondering if I move it and put the dryer next to it instead of on top it will remedy the jiggling thing which like I said doesn't happen all the time.
John,
The person you know that moved their machines to the upstairs, what did they do about installing plumbing and electrical. Another drawback of this old building is that the upstairs is under the roof. There is no attic above so there's no way do get between the walls without trenching into the plaster. I found that out when I had two different contractors to come over and look because I wanted to have the building re-wired.
Stacked unit
Andy
I hope you don't mind me saying, but it sounds to me like you are using a sledge hammer to crack a nut.
As I understand it from what you have written, the issues are:
1. The stacked unit does not fit in with the look you are trying to achieve (presumably vintage) and
2. In a small kitchen you are losing valuable counter space.
To me it seems that the best solution would be to un-stack the drier from the washer and at least store it in the closet, rolling it out when you need it. It will surely be a lot lighter to move than even a portable washer. The ideal of course would be to provide some ventilation to the closet (if possible) and run a power line so that the drier can be used without being moved.
That leaves the washer. I would leave that just where it is and get some butcher block (or alternative finish to your taste) to go over the machine, making it, if possible slightly deeper than the washer. This would be attached to the walls and cabinets around the washer which would remain free standing underneath. Immediately you have now gained at least 2 square feet of counter space.
You could then cover the front of the machine with a curtain or even a door which could then be finished to match, as near as possible, your existing cabinets. This of course would not want to be a heavy construction, as it will need to be removed to allow the machine to be pulled out for maintenance or cleaning.
If it were acceptable, a lightweight ply panel, again finished to match you cabinets and perhaps made to look like a door or drawer/door, held in place with magnetic catches and removed when using the machine, would be another alternative. If you were so inclined, rather than match your cabinetry this could even be made to resemble a vintage appliance, something like a portable dishwasher coloured to match you "new" range.
This latter is all illusion of course, but FAR more inexpensive and less disruptive than trying to remove your laundry upstairs. And of course you keep your investment in appliances which, by the sound of it, answer your needs well.
Good luck with your project, whatever you do I hope it goes well for you
Al
Great idea. A combo unit hidden under the counter. I'll have to check out the demensions of combo units to see if one would fit, but that's a great idea. It could be hidden away behind cabinet doors when not in use. I could take out my dishwasher and put it there. I mostly wash everything by hand anyway. Thanks everyone for all your suggestions.
I'll research to see if anyone makes a combo that small
They are out there by Fagor, Asko, and some off the wall names like Splendide (sp?), but quite honestly you are better off with quality separate units. I certainly wouldn't get rid of Bosch Axxis set for any of the current combo units on the market.
John,
You commented that when I move the washer dryer upstairs that the drain doesn't necessarily have to go into the house drain, but does need to go outside. That means sudsy water would be going into the roof guttering and flowing out into the yard. Hmmm. Have to think about that. What about the upstairs drain. Can it handle the amount of water that a washer pumps out?! Guess it depends on how clear the drains are, right? Wonder if I am going to run into any type of code issues?! My trusty plumber/electrician....he's both....isn't that great?! lolll He can fill me in on that. Upstairs is definitely where I want them to go.
Andy:
What John meant was that the drain from a drain pan does not necessarily have to be plumbed to a drain, that a drain pan can just drain to the outside if need be.
Forgive me if you already know all this, but a drain pan for a washer is a big plastic or metal pan that a washer sits in, to catch leaks. They're available at any DIY store like Menards, Lowe's or Home Depot. They're used with a length of pipe to the nearest drain or to the outdoors, and they are a must with upstairs installations. With a drain pan, even a catastrophic leak flows harmlessly to the drain or outside, with no damage to flooring, subflooring, joists or ceilings.
They can be plumbed to the outdoors (where permitted by code) only because they're an emergency device - I don't think plumbing a washer's drain to the outdoors is legal anywhere any more.
The best washer drain pans are stainless - hard to find and expensive, but pretty much eternal. Plastic is okay, but can be cracked or broken. If anyone tries to sell you a galvanized pan, keep walking - a slow leak you can't see will rust it through, and then when the leak gets big enough to need the pan, the pan's no good any more.
