Pot Filler Faucets - What Am I Missing?
countryguy
May 29, 2007
2,132
Astorville, ON, Canada
Just finished watching another House Hunters Renovation. Over the stove a pot filler faucet was added. I don't understand the concept. The claim is that the cook can just fill the pot at the stove and doesn't have to carry a heavy pot full of water from the sink to the stove....huh? Doesn't the cook have to carry the pot full of water from the stove to the sink afterwards? How does this help? What am I missing here?
Bewildered.
Gary
These shows are ridiculous! Anything to waste money on. I agree with both Gary and Ralph, I’d much rather carry a pot of cold water to the stove, than schleep a pot of boiling water to the sink, but that can’t be avoided, unless there is a sink next to the stove, which I wouldn’t want either
I like my small, townhouse kitchen, the sink is a convenient three steps from the stove, problem solved.
Anyway, I wonder just how much real cooking these show ponies really do in those tricked out kitchens.
Eddie
In addition to what has already been pointed out, I wouldn`t want to use water that has been sitting in a pipe for a while, getting stale and picking up pollutants like copper or plasticizers for any cooking or drinking purposes.
I always run the water until there is a drop in temperature. How you`re gonna do this in such a stupid setup ?
I Completely Agree With All Above Posts
I have always though that this was the most useless item I have seen people installing in their kitchens, and possible problems could be serious if you ever have a leak [ If you want a PF faucet be sure there is a shut off valve under the sink so when either the faucet or the piping ever leak it can be shut off ]
This item should be added to Laundress's thread about useless kitchen appliances.
This is another tchotchke to make your home kitchen look like a commercial kitchen where you might have huge stockpots that need to be filled. I remember a woman writing into one of the domestic websites decades ago wondering if she should get a range with one of the round cast iron hot plates with a burner at the center so it is the hottest position and pans are moved further from the center to comparatively cooler portions of the plate for slower cooking. There were people wildly in favor of this feature of commercial ranges. I asked her if she ran a kitchen where cooking was done in very large pans all day and if she had air conditioning. I did not need to ask if she was an air head. These things take a good while to get hot and they stay hot for hours. I worked for a while in a hospital kitchen with one of these range tops. The heat given off by this plate is tremendous. Anything that spills or boils over onto it cooks on to it and then burns on to it and cannot be cleaned easily until the stove is shut down and the plate has a few hours to cool unless you use a brass brush or scrubber and even with those you have to wear heavy gloves to prevent steam burns, but as John said in the 1980s a Yuppie kitchen had a commercial gas range and unused Calphalon cookware hanging above it because most meals were eaten in restaurants. This faucet is a bauble on a bangle with very little practical use in a domestic kitchen.
In some ways it would be nice, like putting a pot on the stove and filling it there.  I have a big wooden cutting board I place in the seat of my walker, put filled pot in that, wheel to the stove, put pot  on burner and cook.  To drain hot pot, put back in cutting board-lined walker seat, wheel to sink, put pot on trivet on counter next to sink, drain in colander in sink, place hot pot on trivet on counter, and put contents back in the pot.
just guessing here...
<span style="font-size: 14pt; color: #008000;">I can understand how these would make sense in a restaurant or professional kitchen since the busy and generally well-paid chef fills the pot. But like clean up, the kitchen help would probably have the task of emptying the water. They seem silly for the average home and are more of a status symbol.</span>
More junk
I don't need, if im boiling pasta, im not too lazy to carry a pot 3 steps, BUT IF im cooking something already, like beans , a roast etc, I would NEVER add cold water right out of a faucet anyway, I know enough not to ever add cold water to hot food, just as you don't mash hot potatoes with cold milk! its just one of those little cooking secrects that makes a big difference in the finished product.
"always run the water until there is a drop in temperatu
Now that the boilers are set higher due to heating it takes running cold taps for 1-2 minutes or longer before water turns "cold". That is fresh water what is coming from mains in street versus what has been sitting in pipes. Running taps that long just to flush out "stale" water for whatever reason represents an intolerable waste.
Water mains at least in America range from things put down hundreds of years ago (cast iron or wood), to modern PEX or whatever. Joining material ranged from lead to God only knows what else. Either way don't believe water sitting in mains at street is any fresher or cleaner that what is sitting in pipes inside a building.
Maybe the situation in Germany is different to the USA, I don`t know.
Here the water at the entry of a building which is constantly in motion is assured to be safe. In Munich water does not need any chlorine or other treatment for most time of the year unless we had a flood or a similar event. So it "might" get stale when sitting for some time in in-house installations.
Then there is the problem with pollutants from pipework. There is no material known to mankind used for pipework that does not pose a problem at all, it`s only about that some might be worse than others. Copper or zinc for example are important trace elements, but can become a health problem when consumed in excess.
Anyway, per capita water use here is about one third compared to the US.
