Powdered detergents clogging septic lines?
I can see it
The Zeolite (clay particles) don't do alot of expansion while in the washer doing their job in the the limited environment and lesser water levels, but once they hit the septic environment I can imagine they will swell to their full capacity and reek havoc where they land.
Kind of OFF topic
but mine vents through the roof!! and I HATE it!
The laundry room is in the center of the house so it's not possible to vent anywhere but the roof.
Over the years, I've cleaned the vent routinely with an electric leaf blower and even a brush running from the laundry room UP to the vent that exits the roof. It would only take a few months for quite a bit of lint to accumulate in the run before it would need to be cleaned. I could always tell by drying times.
About 8 months ago, I cleaned the vent line really well....My dryer is very easy for me to get behind, so I've been using a mesh paint strainer put into the vent behind the dryer that connects to the wall (sort of like lining the vent with a trash bag, only it's a paint strainer), then connecting it to the back of the dryer - and I clean it about every two weeks. It has kept ALL lint from getting into the vent line and the clothes are drying fast.
I got this idea from a lady and her husband who had been doing this for years in their condo on Gardenweb laundry forum and she said it kept their run really clean.... and at first I was so afraid of it being a fire hazard..I even mentioned that to her....but the clothes dry really fast and the entire run is completely lint free after 8 months.....so having to get behind the dryer every 2 weeks is kind of a pain.. it takes be about 10 minutes to clean and put it back on...........but it's much better than cleaning the entire vent run......It's just good to know I won't ever have to do that again....It's amazing how much lint escapes the dryer lint screen
When the dryer is running the back of the dryer doesn't feel over heated, I've examined everything and don't see it as an issue as long as I regularly clean it. No one else does laundry but me.
Once lived in a two story rental house, built in the 20's. The kitchen on the 1st floor had a vent by the stove. I wanted a dryer, so I moved the stove over (which being modern had no vent) and ran a metal duct from the dryer to the stove vent. It worked great. Never seemed to clog the chimney, either, but that may be because the chimney was at least 8" diameter. I would check the clean out at the bottom of the chimney tube from time to time, but never got much lint down there, either. I would also check with a mirror and flashlight to look up the chimney pipe, and never saw much lint stuck to the walls.
After 12 years I moved out to a mid century (well, '41) home with a standard horizontal 4" diameter steel duct running about 15 feet from dryer to outside wall down in the crawl. It does require brushing out every couple of years. I keep an eye on the dryer vent louvers... when they don't seem to be as horizontal as usual, and/or the dryer itself seems to take longer and its cabinet gets warmer than usual, I know it's time to brush out the lint buildup. One of these days I'm gonna insulate the outside of the duct in the crawl to reduce condensation inside it, which in turn will reduce lint buildup. The kitchen vent in the previous house ran in the middle of the structure, so it probably didn't have that kind of condensation issue.
