Gas problem getting worse
Not sure it has changed a lot recently, but there was an awful turn for the worse as soon as they mixed Ethanol with the gas. It isn't really a problem in frequently run engines where the fuel doesn't age but infrequently run engines have horrible luck. From what I have found there is NOTHING you can add to the fuel that makes up for the alcohol being in it. Hopefully we don't end up with higher percentage blends but I'm not sure they could be any worse.
In many parts of the country it isn't tough to get non-oxygenated Ethanol free gasoline. I've been using non-oxy gas for about 6 years now and I no longer do anything special. I used to use Stabil and drain tanks for the off season etc. I rarely run my lawn mower so the fuel in the tank is now about 2 years old, I start it every couple months first or 2nd pull every time. Snowblower started last weekend first pull on last years gas. I've never had a single fuel related problem since I switched.
Check the link for a list of gas stations that carry non-oxy fuel
https://www.pure-gas.org/
