Pristine Kenmore Free to Good Home
That's the rare model just below the LK that I helped my mom pick out in 1975.  Big selling point was the Quiet Pak transmission, as the laundry room opened onto the den/TV room, and this new Kenmore would be replacing the despicable and ear-splitting '67 Snorge from Hell.  The Kenmore served her for 25 years (could have been longer but that's another story that's sad and irritating) and in that time only needed a belt (the original green ones were notorious for failure) and a new and improved filter (ditto on the original ones).
Todd, this is a very special and tempting, feature-rich machine that is likely the only one that could ever replace my A712, but as long as it has potentially found a good home, that's what really matters.
Plastic Thing
Ken, that's another dispenser for powdered detergent.  When selecting the automatic soak & wash cycle, after the soak and pre-wash the machine would continue into the regular wash and the spring loaded bottom flap on the dispenser would open and allow the detergent to drop into the tub when fill was done and agitation began.  You could also use it for just a regular wash, but you had to set the timer dial for the full 14-minute wash time in order to trigger the detergent dispenser.
The detergent dispenser works on all cycles
Yes, you have to set it for thee longest wash time for each of the 3 main cycles--Normal, Delicate, and Perm Press.
Thanks guys for clarifying.  I had forgotten that the detergent dispenser works on all three wash cycle options, but I guess that's because I can't see any need to bother with it other than with the soak & wash selection.  It just gets in/knocked out of the way when unloading the machine.
In all of the years I’ve worked on appliances I had one of these washers probably about 25 years ago and I parted it out because it needed too much work. I’ve never seen a matching dryer in person and only found 1 picture of one in the archives. I’ve wanted one of these for a long time and I’m sorry that Todd had to give up his collection but I’m very thankful that he was so generous in giving the club the opportunity to save them. Todd I can’t thank you enough and I can only imagine that you may be searching for some oldies on the big island. I couldn’t put this machine away today without this picture.
