Hi everyone!
I'm looking for some advice from the UK twin tub owners. I have a T5088 and the pump doesn't quite work properly. I think it is a common problem - when you turn the water valve to 'empty tub', the water flows from the wash tub into the spin can and when you are emptying the wash tub, it takes ages.
I'm about to replace the wash tub sump hose in the next few weeks and was wondering if there is anything I can do to fix the pump? I'm a bit reluctant to open up the pump in case the seal gets broken and then leaks (no leaks at the moment!).
Is the problem easy to fix, or am I better to just leave it as it is?
Thanks!
Thanks!
