bellalaundry
Well....the other day while I was using it, the machine started to squeal, just a little, and then a lot.
I turned it off and have taken it's skirt off. The pump seems to have become very misaligned. So I took it off too.
This is the second pump in the last 4 years that I have had to replace. Always, right from the get go, the pump valve would either leak out of the drain hose during wash OR leak out the filter during spin. I'm wondering if the wig wag does not move the lever enough for the valve to seal??
I have been using "standard" 3 port pumps.
Were these manufactured to use a "special" pump. Since my model is an Inglis...the model number does not come up on anyones part lists.
I'm borrowing a picture from one of our members that looks to be an exact match to mine.
Guy
Guy
