bazzybtec
Active member
I have a number of these style pumps in my parts box
https://www.ubuy.sl/product/4KSR1QKLS-whirlpool-washer-drain-pump-350367-new
they are 4 port whirlpool pumps that i have for spares however i need to change out a pump that is for a model with a magic clean filter.
Can the two additional ports i believe they are designed for the re circulation of water through a waterfall filter, can they be blocked off at the pump or perhaps filled with water and put a pipe loop on it so that it can be used on the magic clean model?
the pump that is fitted is the incorrect type it is a 3 port version and it does not reverse the flow so the magic clean filter would not be doing its job properly, i have also worked out that is what would be causing the weird siphoning effect that i have noticed with this machine.
