Question about the 1990 Whirlpool DD.
DirectDriveDave
Oct 11, 2011
456
Hey guys, it seems the machine is going to have it's very first "cabinet off" repair and wanted to ask about something.
When I last used it about 2 days ago, I noticed some water on the floor in front of the washer (nothing major, just a little). Going by that and what RepairClinic says, I am suspecting that the drain pump has started leaking.
If that turns out to be the case and I replace it, should I also consider replacing the motor coupling? It still works fine, but it is going on 21 years now.
coupler
yeah,i'd replace the coupler too-its been improved a few times since 1990-also the
4rubber vibration bushings between the motor and the plate on the transmission can
sag a little over the years and put the coupler halves out of alignment,causing
the coupler to wear a little faster-you can turn each bushing 180*so the coupler
alignment is closer after the motor is reinstalled.
PICS
Okay guys, here is what I found. Upon taking off the pump I noticed some rust on the motor shaft, this rust looks very recent and flaked right off, as well as rust coloring for where the shaft goes into the pump.
Pics below show this result. I am posting these because if I put water in the tub, I will not be able to drain it out since the lid switch is disconnected andwould like to hear what some have to say.
also, if this turns out to be the case, does anyone have any experience with ReapirClinic, as to how their services are?
PartsTap.com and AppliancePartsPros.com may be cheaper prices than RepairClinic.  RepairClinic is often touted for their 365-day return policy, but the others also take returns.  SearsPartsDirect.com takes returns, but not necessarily on all items.
Difficult to say for sure on the pump.  There's no obvious mineral deposits on it from a leak but that takes time to develop.  The shaft rust could be from ambient moisture.  Remount the pump, jumper the lid switch, get some water in and have a direct observation of it.  Or go ahead and replace the pump, they're not overly expensive.
Okay, thanks guys!
I went ahead and ordered a new pump, and just in case, a new motor coupling, both should be here by Wednesday.
Oh and Nick, wasn't any oily water, the water I saw was right at the front of the cabinet and was all clear, also looked carefully at the pump hoses and didn't notice any signs of possible damage/leaks.
Old thread I know, and he'll probably never see this, but it's cool to see a small snippet of the underside of that machine and what it looked like. The infamous "1990 Whirlpool Washing Machine" previously owned by YouTuber Sharkie626.
That machine with the way the laundry room setup was and how his camera recorded the audio of it was sooo mesmerizing to me as a kid. Especially with the older drain pump before it was replaced.
This was Sharkie626’s account many years ago, not sure why he left. Probably lost interest, or didn’t post for many years.
Funny when I asked what his handle was in the comments section on YouTube, he said “Don’t want to disclose such information”, but since I seen a thread of his Whirlpool and immediately recognized it and that’s how I found out what his old handle/account was. But since this account is long gone, probably won’t see anything on this site.
Sometimes, people loose interest in a thread or group and move on to something else.
