To take it further, the Mayatag DG906 I have has electronic drying, which is another level: It advances the cycle by the decreasing amount of time the sensors "short circuit"and discharge the shutoff charger switch due to feeling moisture on the metal tabs on the tumblers. It does have two different limit switches for drying: a lower one for permanent press and a higher one for regular fabrics, so I assume it dries permanent press at a different temp than regular. Also, there is damp dry button, which works, but must let the sensors still discharge, a little bit, so the clothes are not completely dry. (The high limit switch in the burner assembly is a different story, for fire safety) Wouldn't a dryer with multiple heat settings have multiple cycling switches, or at least one that could adjust? I am assuming that the Maytag dries the regular clothes to a 150 degree limit till shutoff, and the permanent press button at 135, till shutoff, with and extended cool down period, as labeled on the limit switches. Othewise, why have two cycling switches with different temperature limits?
