Question for the Vacuum People...
bajaespuma
Mar 16, 2006
6,261
Connecticut
What's the best upright out there that I can buy (retail or commercial,I don't care as long as I can buy one without a lot of hassle)?
Remember to support your answers and, of course, we always love a picture or two!
before I answer...
What will it be cleaning?
How important are tools?
What do you want it to do for you?
Kirby. They are metal, they last forever, and clean very well.
I have a G4 that I bought as a rebuild, and I love it.
Um...uhhhh Mr. Gansky......
Might you be in that position so you can recieve that Oreck?
Sideways perhaps???
You'll get more dirt off the floor with a shovel!!!
Kirby
*IMHO* if you are leaning toward Kirby, get a non-powerdrive rebuild. the G-series imho, is too heavy and cumbersome. Baja, you really should tell us what your cleaning priorites are, and whether you are willing to buy vintage or not. is weight an issue? do you use the tools a lot? is stair cleaning important to you? also, tell us about price range. for example, if you want cheap, the Hoover Tempo is very nice. if price is no object, the Lindhaus uprights can cost five times as much as the Hoover. be more specific, Baja
I've always preferred tank vacuums over uprights simply becasue with a tank vacuum you can clean a wide variety of surfaces above the floor. With an upright, you are limited to their specialty of cleaning carpeted floors....a job which they actually do better than tanks though. So, which tank do I prefer? I like the Electrolux and Tri-star (Compact) vacuums the best. They are built incredibly well, and will last generations. They also come with all sorts of neat attachments for just about any job. When it does come to uprights, I like the Kirbys because they possess the same good build quality. Another thing I like in a vaccum is the bag before fan configuration. This keeps solid objects from damaging the impeller inside the vacuum because they are filtered out first. This is one disadvantage of a Kirby...luckily, changing the impellers on those isn't too hard.
Really though, cleaning effectiveness is affected by moving lots of air, not pressure. This is what is rarely advertised by vacuum manufacturers (rarely do you see a CFM rating on a vacuum cleaner!) any vacuum that moves lots of air will do a good job, no matter how much power it uses, or how much negative pressure it can generate. This is an area that I think the Oreck vacuums fall short on. They create a lot of pressure, but don't really move a tremendous amount of air.
The second half of cleaning effectiveness is good filtration. I've rarely seen a bagless vacuum that really filters all that good. The ones that do still have parts that need to be regularly changed, so what's the diff between that and a bag? This is one area the Orecks are good at, and so are the Tri-Stars too!
Another important thing to keep in mind is parts avaialbility. The cheap "fad" vacuums that are sold at most of the big box stores will probably not last very long, but that's not a bad thing, since these important parts like bags, belts and such will probably be discontinued rather quickly. This is one of the ways the manufacturers "purge" the field of old machines that escaped their engineered in planned obselecence. (also done quite heavily in the electronics industry)
My only gripe about buying a Electrolux (aerus), Tri-Star, or Kirby these days is that you must typically deal with shadey salespeople who over charge for the machine. The worse part is when you won't purchase one on the spot after the demonstration, and you cannot get rid of the sales rep! You may be able to buy an Aerus at a real storefront, but I don't know of any of the other two that are sold in real brick & mortar stores
If I was just going out to buy a new upright with no interest in all things vacuum I would buy a Kenmore or Panasonic because they're good vacs and reasonably priced. But seeing as I like collecting vacs etc I couldn't do it. I'd rather something vintage or really well built. Personally I think the Kirby Legend Heritage II is the best of all the Kirbys. non self propelled, great carpet cleaner and not as bulky as its predecessors nor as heavy as the self propelled G series. It's also user fixable for anyone with a minimum of talent and should last forever. PLUS you can get them CHEAP CHEAP CHEAP.
I would say that the best vacuum is definately the Simplicity Synergy/Riccar Radiance. Its very powerful and well built.
For carpet cleaning, I prefer a machine with good agitator and nozzle design over one that moves lots of air. Carpet fibers put up too much resistance to overcome with suction. A good agitator will brush the nap aside and vibrate the dirt loose. You only need enough suction to move dirt from nozzle to bag.
Unfortunately, marketing people have found that agitator designs aren't exactly "sexy." So while Hoover once bragged about its Quadraflex(TM) agitator, and Eureka boasted of its Vibra Groomer(R) brush roll, these days it's all bagless this, clear plastic that. Make it flashy, so it stands out on the shelf.
The soft-bagged Eureka/Sanitaire uprights still have the "Vibra Groomer" brush rolls, and Hoover's commercial uprights still have the fundamentals that made the company famous. If you're on a budget, the $60 Hoover bagged Tempo that brettsomers mentioned is the best of the sub$100 crowd. On the other end, Kirbys are capable on carpets, move plenty of air with their attachments, and last practically forever. You can get "Brand new in box" Diamond Editions on eBay for $800 or so, and used ones are even less.
The Synergy/Radiance sure looks like it has what it takes, but I've never seen one so I can't say for sure.
I will vote for Kirbys as a whole and Royal Metal uprights for carpets and rugs.I have a Riccar Radiance-and these can clog.the performance of the kirby and royasl is better-and with half the power use.the fan first or direct air-Kirby,Royal,Hoovers,Eurekas,Riccar Radiance,Orecks(those are fan first too)Is their high efficiecny its better to push the dirty air into a filter system than trying to suck air thru it like clean air machines do-hence the larger higher current motors that have to generate morte suction pressure.Orecks are hampered by their tuiny fans and their high RPM motor.Kirbys and Royals,and some others have larger fans and lower RPM motors-hence those last longer and are more efficient.I see many Orecks in the Vac hospital "Morgue" out here.They get stripped to fix other Orecks.for cansisters The TriStar Compacts are very good-quiet,powerful and efficient.Most if not all common cansiters are the Clean air-filter first design.Canisters rely on suction pressure more than high CFM to do their job.The only "Canisters" that could be direct air are the Kirby configured as a canister and the commercial NSS Model "M" vac.These clean by high CFM rather than high suction pressures.
Aerus
Aerus machines are still sold DTD.Even if you went to their "store" they would still have to send a salesman to your house.Like Kirby,rainbow,TriStar,filter Queen,etc they cannot sell the machines out of their "store"only parts and supplies and repairs can be sold thru the storefront.the store serves as the local sales headquarters.they also would store their stock of machines there.Many DTD vac dealers don't have a store at all-just a small rented business front or room to store stock and a place for salesmen to meet and pick up machines for sales calls.Its unmanned for most of the time.
More specific
Sorry for not being more specific. I have an extensive collection of Electroluxes, so I use one of them for bare floor and above the floor cleaning. Presently, I have an old plastic Hoover Elite 200 BOL that I inherited from my parents. It's OK but it won't last much longer. I'm looking for a simple, old fashioned kind of upright, rather than the bizarre looking toys that seem to be the only thing available in stores these days ( why would any thinking person want a bagless machine?). I've read some of the intelligent discussions on this site concerning agitator brush configurations, speed etc. So I'm looking for the most efficient, preferably also the quietest, upright with a bag for deep cleaning carpets, orientals and broadloom. I wouldn't mind it at all if the upright could clean bare floors as well. And yes, I'm willing to find a vintage machine on ebay if that's what's good. My local vacuum guy once recommended a simple Panasonic to me and that's along the lines I'm thinking. Was Gansky's recommendation of the Oreck a joke or for real? CU always seems to say that their performance is rather mediocre, but then I feel the same about CU alot of the time.
The Oreck
It is a very simple design and works well enough. I really like mine, but it sure isn't quiet. It has to be one of the loudest machines made, especially on bare floors. I love the old Panasonic design. Maybe you should try it out for a few days if your vac shop will allow that. Tim
I have had several clients I clean for who bought Orecks over the years and I (and they) have been disappointed at their cleaning ability over time. They work great if your goal is a quick, surface cleaning/sweeping, but they really have little or no deep cleaning ability - especially once the bristles on the brush-roll start to wear down. I heard one person at the vac convention last weekend describe them as a weak power-nozzle with a fan and a bag. I wasn't too surprised to not see one Oreck displayed (even in the "Free" pile) at the convention and found that most collectors and vac-experts really don't consider them a real vacuum cleaner. It just shows you the power of good marketing though - they sell a ton of them!
I love my Hoover Concept series cleaners, Sanitaire makes a very good upright which is what I use for work and the Kenmore/Riccar/Simplicity/Panasonic designs are all decent machines too.
Kirby G3
I clean 2500 SF of mainfloor office carpet with a vintage Kirby G3 with TechDrive. It is quiet and smooth as silk. The only problem is that I often feel underdressed. The TechDrive is like having a dance partner and I feel I should be wearing a tux.
Love those Kirbys for office cleaning - I do a dental office with a G5 and it never fails to clean perfectly, I tend to dress down a bit though...
Your appliance-art is fantastic! I love the "J. Doe" style robots, Fred, Jeff and I saw the display window of your offices in Benson when they were here - such fun stuff.
