Ranges
That's a nice microwave range Greg!  Do you know how old it is? It looks similar to your GE but I guess it should be quite a few years older since it has convenience outlets... (I think they were banned in the States in 1976).
Versatronic
Greg, you've been looking for a Hotpoint like the one the one original to your house. Who knew you'd find one with a micro combination. I had a GE Versatronic and loved the way it shaved time off anything that would normally roast or bake. I'll post pictures of it after I get home.
this is a 1987'ish TOL
Sorry to disappoint you Gansky but that is NOT a TOL 1987 Range. It is a a Circa 1979  one or two steps down from TOL. My mom bought that same range in Harvest Wheat in Late 1979. The only differences between the one my mom had and the one in your picture is the fact that my moms had a black glass panel door and a Green LED touchpad timer control (much like the ones used on the Magic Chef Microwaves of the day).....PAT COFFEY
PhilR
Hi I'm not good on the tec. stuff. I know our cooker point is rated at 60 amps 250 Volts and I'm wondering if its possible for me to ship a US range and use it here
Sigh!
Greg:
That '87 GE is a nice, nice range - why can't something like that turn up here in Waterloo? Even with the woodgrain and the digital timer, it's head and shoulders above anything I've seen here in forever.
I am currently on a mission to get the landlord's BOL range replaced with a self-cleaner - I jes' cain't take hit no more. Obviously, if a GE J757 fell out of the sky, I'd be the happiest camper alive, but my standards are becoming more flexible by the minute. It's as bad as closing time at the bar, LOL.
This is a J757- made for several years in the early '70s. As you can see, it's basically an Americana with the upper oven sawed off:[this post was last edited: 11/30/2012-06:42]
Mike,
Some members might know better than me since I've never been to Europe... But I can tell you that electric ranges here use 120 volts for things like the oven lamps, fluorescent lamp, pilot lights and the clock so you'd probably need a transformer for those and the clock would still run too slow because of the 50hz... And some older ranges have 120V burners (the 5 heat, 7 heat and others like GM's "Speed Heat" burners use 120V but regular 240V burners with infinite switches should be ok).  But many ranges from the 1960's and on don't have that. For example, my 1960 Frigidaire Deluxe has all 240V burners with infinite switches so just the lights and clock would be an issue... And I know that some clock motors were available for 50hz but these might be hard to find... In my Frigidaire documentation, there are part numbers for some 50hz clock motors...
Well from my experience I always used 120 volt heating and not appliances: portable range, sunbeam fryer, lamps, percolator coffee makers (including small motor ones my osterizer blender, Sunbeam Mixer, conair hair dryer etc...) with simple portable voltage converters 1850 watts and other one 2200 watts, it is years we have these appliances used regularly and we never had a problem with the difference of Hertz they works just like they should ,just the voltage gets converted with these converters not the hertz, specifically about the matter we're speaking of I tell you I have a 1100 watts portable electric burner range since 5 years and element works just like it should....
I knew the difference of hertz may become slightly dangerous for certain appliance types and if are used continuosly all the time (for ex a refrigerator compressor)...
I've read that generally this is not a big problem when you use a 60hz hertz appliance with 50hz, more if you use a 50hz with 60hz...
So I guess even a full size electric stove should not suffer the difference of hertz, I can just speak for my experience with my appliances, I'm not a tech but my appliances never did...
Here are some info I've read, not sure if fully correct:
I remember I've read once in an tech website a discussion (a girl asked how to run a 115 volt KA mixer in Italy) that a part the obvious converter suggestion, they stated to buy a japanese converter to convert 220-240 to 100 volt, they said that if you're using 60hz appliance with 50hz a general suggestion is to reduce respectively the the tension of the same difference coefficient so 115 should be 105 or 100 volt to avoid any possible damages that might occur, not sure if that is correct but that is what it was said....
But another guy stated that usually for heating and small motor appliances like toasters, blenders, mixers etc hertz difference usually never give problems, just for certain types of appliances with bigger and more sensible and complex motors that runs for long time like for ex a refrigerator compressor you could meet an hazard of overheating, motor effort and generally a reduced life of the motor. I've read in the same blog the example of the Japan where they have 100 volt 50hz but they use American appliances all the time and in US also use Japanes appliances with no problems....
Clock and lights issue:
I have a 70s Sears flip alarm clock that was of my granma, she gave me to bring with me to Italy when I was 10, it is my daily driver alarm clock and I use it with a portable travel converter 50 watts plugged there since 1999, it works like a charm with 50hz as well, never missed a second.
Now I'm not sure if it was supposed to work with both hertz but it states: 115 volt 60hz on the back label...
Not sure about a stove clock but if it is the same of my alarm clock it should work anyway I guess.
Lamps problem:
I have some lamps and lava lamps that I purchased from USA that still have 120 volt bulbs and works just as they should with the transformer...bulbs are nothing but heating elements so they shouldn't suffer changes of hertz.
So, personally I don't believe the hertz difference might be a problem even for an electric stove. I just told you what I think and what I've experienced and read, I'm not a tech maybe someone else might be more correct and give better advice/ info.
Personally I'd be more worried about importing costs though! LOL
Good luck
Upper end ranges.....
Well they were of course one of the most known range brand of that time....
I don't recall I've ever heard about Gasfire being sold/advertised as a superior quality (upper-end) appliance, rather the advertising was pretty anonymous and almost non-existent.....
Is still a brand today, today Gasfire brand got bypassed alot, it is not so known today like before, of course not as Nardi which is probably the most known brand or Candy, Rex, Zanussi, Zoppas which are famous europe and worldwide also.....
My experience about Hertz is different: On one side there was a Norge fridge that my parents bought in the middle 50's and my mother sold in working condition after 1990. That was a wonderful and rather biggish fridge that never gave any problem and worked with a transformer for 220 to 110 volts, since here we have 220 volts 50 Hz like almost the rest of the world. BUT my (then) girlfriend brought from the USA a radio-clock that never worked here and we knew it was because of the different rate in Hz. And years later in the 90's (to be exact) we used to live by the Brazilian border in norther Uruguay and I went to a shop to buy a TL washing machine, with electronic controls and the attendant told me: if you're going to use it in Uruguay it won't work because of the Hz although Brazil in the southern area is 220V.So I didn't buy it and instead I bought and Italian Ariston FL that worked for some 18 years. That's my two cents. Gus
Gus.... I think it's different for a simple reason.....
That is simple Gus, I forgot to metion it but of course alarm radio clock and elettronically stuff like LCD, TV will not work with a different hertz, that is obvious, they will burn out or go crazy.
That is clearly warned in all the packages of converters that they're not suitable to be used for electronaical stuff like that, some even states they're not good for writing machines and calculators.
But for mechanical clocks and most motors as long for heating elements I believe there is no problem, my flip alarm clock goes strong.
about your efrigerator, I believe compressors at least newer would suffer hertz changes at least I've read so that they're delicate to that, infact in many step-up down converters is stated that are not okay to be used on refrigerators along with LCD and things mentioned before....
Better so, it means your refrigerator was one of the ones having a compressor that can support it.
Anyway electronical stuff suffer changes of herrtz not electromechanical stuff
Freddy,
Your experience with the flip clock is interesting. I thought these also had synchronous motors.  Unless yours is a kind of self-winding clock with flip dials (I've never seen that). Those I have seen mostly have Copal or Copal II motors.
Phil
I went to take a look at my alarm clock as I wanted to understand or read something....I noticed it does have a switch under that you have to turn with a screwdriver for the cycles, 50 and 60.
Never noticed it before, probaly it was setted so from my mother when I was a kid and never noticed it.
Anyway you're right, if it is true that electromechanical clocks runs thanks to cycles so a 60hz clock will not work with 50hz!
I just googled that synchronos motor and read about it. So it works with the cycles!
I did not know that!
You never stops to learn!
Blows my mind
...that stoves and many appliances from the 50's and 60's were not only full of details in function but over-the-top design and appeal. As someone said above, today's appliances are generally boring. If they have glitz and color, they won't be around like the 50's and 60's appliances are today..52-62 years later. Great thread. I wish I had something to show off, but I did find something really interesting...see link.
http://atlanta.craigslist.org/atl/atq/3287398991.html
Phil....
This discussion about the clocks made me so curious that I wanted to understand more of my clock and generally about electric clocks and how they works and learned alot of things I ignored, thanks!
I spoke with my sister yesterday of it about the alarm clock, and she does remember that granma gave it to us to bring to Italy because she said it was not working for her and had a problem of electricity, I believe that she knew of it by an electrician I bet she did not even know what cycles were, not sure what was the exact origin of that clock , she probably bought it used.....
I did forget about this story, I just remember I liked it so much with all the lights etc and was so happy to have it and my mom had to buy a new bigger luggage to fit it into...
It does have an hidden switch to twist with a screwdriver stating 50 and 60 on the 2 sides under the rear panel on the right side....
I believe it's the cycle switch and now it is pointed on 50, label tell 115/100 volts 60 cycle (actually 60 cy) a corner is cut so maybe it stated 50 cycle also, of course it's so....
I think it does have a kinda brake or mechanism inside to make it work right with both cycles and speed also....just guessing, or a thing converting hertz, not sure if that is that simple though....you look more expert than me.....
I'm not into clocks as you can understand, my father is more being a jeweler, I gotta ask this to him....
The clock states:
Made in Hong Kong, no date available.
Warnings are printed in english and japanese/chinese, but who can tell exactly? LOL
I believe it is from late 70s from the style.....
I also googled the matter and looks common to find american people with clocks running slower in 50hz countries, so another thing confirming you were right!
I never noticed my appliances works slower though, elements does not in my experience and nor motors runs slower significantly.
My mixer mix as it should blender also, fryer and steam irons all works like a charm and lamps too, so anyway what you could meet with an electric stove is the problem of the clock only I believe...
Anyway I'm glad I learned a new thing thanks of you Phil, that is good to learn of it that a 60 cycle clock will not work with 50, and this is good for many reasons apart personal culture...and specifically because I was watching one of those VTG electric coffee makers with built in clocks to give to my sister for Christmas!
Thank you for making me realize that.
