Hi everyone,
I inherited a RCA Victor Custom 60 EDE-600 dryer that has been with my family since my parents bought it second hand in the early 70s. I came across this forum while trying to learn more about it - very cool that there are people out there collecting vintage appliances! They don't make them like they used to.
Does anyone have more information about my specific dryer? The serial number is 540890. I found an advert from a newspaper from October 1969 where this model was being sold for $170 ($1350 in today's money), but I'm curious who the actual manufacturer was (Inglis? Whirlpool?).
I recently found the dryer to be running a bit hot, so I tested the thermostats with a heat gun and took temperatures with an IR thermometer. The low operating thermostat was opening at 200F instead of 135F, and the high was opening at 260F instead of 165F. They’re Thermodisc branded and I assume the original parts. The safety thermostat looks different from the Thermodisc ones (similar to thermostats being sold today) and it opened at its specified 245F, so it has possibly been replaced. I plan on replacing the low and high thermostats with Supco LS2-140 and LS2-175 ($7 each). They're not exactly the same but hopefully that's not an issue, as they're the only ones readily available around here.
A while back, one of the connectors at the heating element had burnt up and failed, causing the dryer to stop operating. I found that a prior repairman did not replace the connector properly (bare wire doubled over itself and tightened against the terminal), and I assume the increased resistance from a poor connection damaged the wiring. I've since replaced the connector and all has been well.
The drum belt currently has cracks all around - not sure if it's original but the belt is labeled FSP 337019 (94-1/8" long, 3 ribs, 1/4" wide). A replacement belt was difficult to source but I found a retailer that can special order a Supco LB274 belt ($14). I might pick up a spare to have on hand in case it becomes no longer available.
And a disgusting “repair” from a few years ago – the exhaust vent was stuck open and flies got in and laid eggs in the dryer exhaust. They also got past the lint trap and into the drum… Fun times.
