sudsmaster
OK, got the outer tub out - the worst part was removing the hose clamps on the recirculating filter fitting to the tub.
There is more rust to be found... one of the mounting holes has an extra hole due to rust-through. I think I can fix it with some JB Weld (epoxy plastic weld), and maybe a larger rubber washer and stainless washer (the ones I got with the repair kit are almost big enough). There are also what look like rust specks elsewhere in the bottom of the inside of the outer tub... I will see if I can use Jasco rust renovator on them (as long as it doesn't damage the remaining porcelain.
The alternative is to look for a replacement outer tub (unlikely) or have the hole welded up and the tub re-porcelainized. I work with welders so that's no problem, but the re-porcelainizing might be tricky; I don't know of any shops in the area that do that. Since this washer will see only occasional use, I'm thinking the JB Weld is the way to go.
The base plate has rust in areas where there was leakage from above; the worst will be treated with Jasco, and the the entire base plate will get a brush-on coat Rustoleam fish oil red rust preventative primer. I will treat the inside of the cabinet with the Rustoleum red primer also. I might omit the top coat since the red primer needs to age quite a while before it will allow a coat of paint to really stick, and it will never been seen once the washer is assembled.
The drive block came of very easily, so I think it can be re-used no problem. The centerpost is heavily rusted between 1 inch and four inches up. The top still has its chrome plating. I chipped away the worst of the rust, the rest will get the Jasco treatment. Fortunately there's still good chrome and smoot paint where the center seal "donut" will seat. And there was no sign of leakage past the center seal. I will have to mask off these areas when I get out the Jasco, since it eats paint.
If anyone knows where I can get a replacement outer tub...
