Bulky Items Cycle
On my Duet the bulky cycle did not add more water. Instead, it would provide breaks in the tumbling action to make sure the entire item got saturated. I only used that cycle once. I want my king sized mattress pads CLEAN, not just soaked.
On that same machine, it was either the "Active wear" or "Quick wash" cycle that used more water.
With the Affinity I have now, which is teetering on the brink of POS status for cleaning ability due to its skimpy water levels, the "Permanent Press" cycle is the shortest at 36 minutes. Otherwise, you're looking at just about an hour to run a load through, and that doesn't count all of the BS rebalancing time.
