Real?
Loading
Yes, there is absolutely a proper way to load a Frigidaire. It is loaded in quadrants. Imagine an X in the tub, load it that way stacking as you go. In my 1-18 I fit in 8 full size bath towels and top it off with around 20 washcloths, set it to maximum fill and maximum wash time. In about 10 to 15 seconds they're turning over nicely and come out smelling great!
Dan
I have so many Maytags, I needed to 'branch out'. My mom had a Frigidaire rapidry 1000 in 1967.
I have always wanted a Frigidaire, and this one is in great shape.
Thanks for the kind words.
It is so different than a Maytag. My mom had the choice of a Maytag or a Frigidaire, and picked the Frigidaire. Perhaps it was because my Dad worked for General Motors at the time.
It was a wonderful machine.
This was similar to my Mom's machine. Four water temp combinations; Normal wash or Gentle wash; Full Load or Partial Load; and there was a Normal wash cycle and a Soak Cycle.
A very fun machine! Very few noted in my area. I had only ever seen one here and one in Delaware. Tucson, AZ changed all that a few years ago with a few fabulous wash-in weekends at three glorious homes including Ross' place! The Frigidaires there were just as fun!
Overall I thought this machine was in excellent condition and was relativley clean.
Working to get some videos posted and linked on YouTube, ASAP.
Max Fill?
Should the maximum water fill come up to just the last ring on the agitator?
There is a setting that can be turned on the pressure valve, and I am guessing it is for more or less water at each setting.
Although the tub looks much wider than a Maytag, can you fill it fuller than the Maytag(and still achieve an ok rollover)?
About how full should you fill the tub with dry clothing?
Gary, you "underfill" a 1-18 with water and put clothes into it that looks like it would be "overloaded" for the water level in order to achieve great rollover!!
Underload
Like this!
<object width="873" height="525"><param name="movie" value=""></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="873" height="525"></embed></object>
Underload
Yes, start the machine with a lower than expected water level only adding more if necessary.
Tim, the above video is not mine. Just one of my favorites on the tube. However, when I do edit movies, I use Corel DVD Moviemaker.
Malcolm
Am I going to love this machine more than the love I have fo
Two different beasts, both worth of equal intense love. Frigidaires are my favorite. Gary, Malcolm better explained the concept of what I was trying to get across. And this video bears that out. You select a much lower water level than you would think is appropriate for better turnover. Or look at this another way, I put two 3/4 full equivalent Lady Shredmore loads of towels into a 1/18, so that was 1.5 loads from a WP DD type of machine into the 1/18 on the full water level. It dind't bat an eyelash, took it all like a champ.
Gary, you were right about bring home something other than a Maytag. Congrats on the wonderful find! It sure looks to be in great shape, and you guys did a fantastic job cleaning it up.
The first number in the serial does designate the year (1975), but I just learned something from the website you listed. The website is getting the month possibly from fourth digit, being the F for June.
The video Malcolm shared is a clip of my 1975 WI Frigidaire, put together sometime earlier this spring. Don Shier gave me the tip about using a lower water level (and IIRC, the advice originally came from John LeFever), and it worked wonders when I had the 1-18 in service.
Maytags and Frigidaires are certainly two very different washers, but it is nice to know that we all love them for what they are. Enjoy!
Ben
Ben
On the Gentle speed(spin) and with min water level, it seems to take a while before the water empties from the tub. On normal speed, the water empties right away.
The other day, when Steve and I were washing a load of towels, the machine seemed to slow down it's pulsations a bit, then go back to the normal speed(on normal agitation).
I guess I can't ask for miracles on a machine that is 35 years old.
I am really glad to have it, and it was $50.
Came from a house that had green and orange shag carpeting, yellow counters, and avocado green appliances in the kitchen(by the time we got there, the appliances were long gone).
I will not use this as my daily driver, but will be in rotation with all the Maytags that I have.
Gary congratulations on your 1-18 great washer when i first started to work for appliances in a secound hand B-stock store... there where alot of machines coming back and one day i found one yellow with a window a bought it for 50 dollers lol and it is at my brothers house.
Since then i thought i had my dream job but that's another story, jumping five yr's later, something came back it was another one in white so i got a friend and i took it home and it works like a charm it is true what the guy's here are saying the seems at a nice med water level it has a the best rollover ever and i love it when it has a small pause and then it dunks everything down.
Since i don't have room i will be giving it to Martin...
( Yogitunes ) later when we get the chance the yellow one.
I saw at some where that someone posted a softner cap which is rare i hope to get one someday who know's,
and Ben does have the best video's always looking forward to seeing them.
Gary the circle spray well who wet's better i do recall a Speed Queen does this but not as forceful, i tell you there is no need for double rinses in this guy the rinse & spin cycle rocks... so enjoy your machine and good luck.
I think we have the same washer.
Here's mine.
Darren k.
Darren
Should I be concerned that the pulsations slow down and speed up at times in the Normal agitation?
Also, should I be concened that the water takes time to empty from the machine in the gentle spin/or knits and perm press cycles?
The machine spins like crazy, and, I actually think it removes more water than my beloved Maytags(YIKES).
Today's wash load
A set of King size sheets with pillowcases
5 bath towels
3 wash cloths
2 hand towels
Water level set just a bit below normal
YAY!
The rollover was FANTASTIC.
Thanks to all for the suggestions of using less water to achieve rollover!
Gary it does not sound normal to me,
but i no it does have a stepped spin first slow then
fast at 7.. something or more then 640 RPM's if not mistaken someone here should no more about the the pulsations from going to low and high in a normal cycle i hope it is not a bad fix.
Good luck Gary and most of all have a great time with it.
Darren k.
