Getting a direct drive wash basket loose
Hi Henry, can you remove the lock nut ring spray plenty of penetrating oil on the basket, drive block, etc. then screw the lock nut ring halfway on while holding the basket up with one hand take a steel hammer and smack the lock nut ring a few times that will make the basket loose and from the basket drive block.
I do this several times a month in a customers home when the basket must be removed for service and you don’t have a week to wait for penetrating oil to work, etc.
As others mention you can clean this machine up pretty well without taking the basket out.
One thing to consider when you said that, your mom mostly uses warm water the warm on this machine and the hot are greatly reduced from what you would normally have for the most part. This machine should probably be used on hot water for good cleaning . Conversely, you can get a good cleaning in colder water by using a lot of really good detergent but that’s expensive.
I would not try standing in the basket on a direct drive machine. It really doesn’t loosen the tub that well because of the suspension system and it’s dangerous I do, however, recommend standing in the basket of a belt, drive whirlpool that works very well. You need to only stand in it and rock back-and-forth about twice in the basket always comes loose on the belt drive washer
John.
