Rebuild of Maytag Dryer for my Mother
beekeyknee
Feb 5, 2010
1,792
Columbia, MO
I spent all of last week at my Mom's house. I finally got around to fixing up the dryer that matches the washer I rebuilt for her in 2011. The LAT9800AAW. That was the long post of the machine I swapped the transmissions around. Anyway, here's what happened.
Pic 1: Guts out and cleaned.
Pic 2&3: Front tumbler glides. I didn't replace these because they didn't look too
bad. What do you guys think. I have new ones. I can take the front off
and replace them when I go back if need be.
Pic 4: The tumbler wheels were still good. I took out the spring washers and
replaced them with mylar spacers. They won't squeal like the spring
washers sometimes can.
Pic 5: Guts going back in.
Pic 6: Front bulkhead back on. The felt on the bulkheads was worn and cut in
one spot, so since I was going to Kansas City anyway, I went to Marcone
Supply and got new felt seals, a new idler wheel, and a cycling
thermostat. I suspected the stat was bad and Drew and Mark confirmed it
for me. I didn't want to just go buy it w/o being sure. That thing was
around $43.00. It's got five wires attached to it and practically runs
the whole dryer. I guess that's why it's so expensive. I had bought a
new belt and filter for it 3 years ago, so there's $200.00 + wrapped up
in this thing. Didn't think it was going to be that costly.
Pic 7: I took the front panel off the old girl. She hadn't been looked at for
three years. She was fine. Just a fine spray of turbine oil had spun out
from the tub bearing. I wiped her all down and put her front back on.
Pic 8: Here's the dryer directly across the room, just two steps away from the
washer. Now too bad of a set up. We spun the deep freeze around which
made more room for the dryer and some clothes baskets on the side. It's
the first time in my Moms life that she's had a matching laundry set.
She was pleased with the way everything looked. I guess some day they will
belong to my sister, as she plans to live there after Mom and Dad are
gone. Who knows - The washer and dryer may out live her.
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?38714
Nice job! I just did similar to my FIL's Maytag. His needed a belt, and when I got into it, the front glides were badly worn. Rollers and felt seals were good, so I lubed the rollers. installed the glides and belt, and cleaned out the inside.
Runs like new!
