Great Job!....
as for the clutch, you need to inspect it, or for the most part, is the little actuator there, and functioning....
for the most part, these are rather quiet machines, its the filter flo that sort of makes all the noise....i didn't realize that until I pinched off the hose, and realized how smooth a machine it is...
now if you get a lot of chatter with the hose pinched off, it could be the clutch, or something simple as the clutch loose on the shaft...
I had to modify an actuator for one of my clutches....but as long as it works, who cares...actually with this spring setup, it may never fly apart again...
you may want to modify a few parts...such as removing the restrictor in the water valve...and altering the fill flume either way to spray on the clothes...and a cable tie on the lid switch...
the ramped is about the best agitator, but I also like swapping out different ones for observation of wash actions...
also, secure the tub should you ever have to transport it...
keep us posted....
