Washers For Under A Belt Drive WP Built Outer Tub
These are to prevent the outer tub steel from bending too much and causing the porcelain from chipping off.
You can probably use many different materials as long as it is not over 1/16" thick, cork, thin non-corrugated cardboard, flexible gasket or vinyl sheet will all work.
