Thinking about my current dishwasher-less situation and realizing that being over a sink of hot water three or more times a day is *NOT* up one's street, had a thought.
For D&M design motors such as my Kenmore/Frigidaire dw is the shaft nothing more than the screw which goes through the pump/drain/impellers, etc... and holds the whole thing together? If so as noted in another thread the screw/shaft on mine has shorn itself apart; but wondered if possible to get the remaining portion out then simply install a new pump/wash assembly using a new screw? This to me seems not only a less expensive option then purchasing a new motor, but an easier repair as well. One did test the DW after removing the broken off screw and the motor seem to run perfectly. Am guessing it was the rusted shaft screw somehow binding the motor up from moving that was causing the humming sound. If one let this go long enough the thing cut itself off out of some sort of protection.
Thoughts?
Thoughts?
