Removing front plate from dispenser drawer on Miele washer?
jhanson
Aug 23, 2020
6
Denmark
I'm trying to remove the small front plate attached to the soap dispenser drawer on a Miele W5801 washer with slanted fascia panel. At first it seemed to be an easy job, but I simply cannot figure out how to remove it without high risk of breaking something.
Attached is an image I found of an identical drawer with the front plate already removed. It seems like I should just pull straight up, but no luck with that so far.
Any ideas?
JHanson
You need to remove the plastic card in the front (that's the one with the Miele model numbers written on)use a thin flat headed screwdriver in between the card and the drawer and press it downwards, it should then pop out and the screw should be visible
Miele_User,
Thank you very much, that helped me remove the front plate.
I found out that inserting a toothpick in the space between drawer and plastic card, that became visible after pressing down with the screw driver in one side, made it a little easier to remove the card as it would prevent it snapping back when pressing down in the other side.
