oldschool
Well fellas, I've managed to break down my A606 to the point of finding my agitation whoa's. The 4-groove pin that retains the agitation pinion gear broke (only half of it) and got itself wedged between the housing and the intermediate gear. I've been able to find almost all the parts to back me out of the tear down. Shipping errors and out of stock issues has plagued my time line on getting this machine back together.
I have a few of questions remaining.
First, how important is the wicking in the upper housing for the agitator shaft? Mine is completely gone. Any substitutes that can be had locally? I have found it but this $8.00 minimum shipping on a $4.00 part is getting old. I'm sure I'd like to put something in there. I feel that it would store or hold if you will, lubrication for the upper bronze sleeve until the machine came up to speed and the lube would walk up the shaft.
Second, is there any other way to remove the brake assembly housing other than using the housing removal tool. I don't want to spend 50 bucks on a one time use tool. I did find one place that has one for $20.00 however. But still, one time use. I did remove the bottom part of the brake housing using the longer screw method. (I wanted to check the upper bearing of the brake assembly). I'd like to paint the inside of the base pan (rusty) before reassembly. Yea, I could just mask it off but I'd like to be a bit more thorough. I want to get another 20 years out of this machine and from seeing how robust these machines were built, I don't see any reason why that wouldn't be possible.
Third, I can't seem to find the transmission lube (Maytag brand). It's one of the back ordered items. The old lube appeared to be similar if not the same as 90w gear lube. Can I substitute?
I may have some more q's later but for now thanks so much for all the help up to this point.
http://www.automaticwasher.org/TD/THREADS/VINTAGE/2010/26631.htm?25
