Gas lights
Ref:Are there any remianing gas lighting fixtures that still work with gas?
Hi Kenmore 1978,
No the lights on the second floor were replaced in the 1920's. They do hang from the original gas lines however,same as the first floor.
The chandalier that is pictured in the photos above the dining room table originally was gas and electric,as I told you before. It was not hung by a chain at that time,it hung by a painted pipe.The pipe connected to a hollow decorative "bail" type piece,and one side of the "bail" had the gas line in it,and the other side had the electical wires enclosed. A glass chimney rose up out of the top of the chandalier,and the "bail" came down and around on both sides of the chimney and attached to the metal rim around the glass at the top of the chandalier. Sometime in the early 1930's the chandalier went through a conversion to electric only,and was simplified,but dignified as well. Gone was the clumsy pipe,bail,and glass chimney,replaced by a nice looking,and simple chain.(easier to clean too) There are obvious signs of the convertion if you see the light up close.
Now I will get to the gas lines. There are two gas "feeder" lines in the floor joists,visible from the basement.One gas line fed the lights on the first floor,and the second gas line fed the lights on the second floor. They are both disconnected. The reason they are disconnected is that this house was moved to it's present location (about two miles from it's original location) in 1930. By that time gas/electric lights were a thing of the past.
Thank's
Rick
