philr
Ken,
The picture you sent shows a 1966 DCIK or DCIFK.
It looks very similar to the 1965 model but the controls are completely different. It was the only model to be available in that color that year (and as I told, it replaced pink that was last offered in 1965).
It has an electronic control and moisture sensor like Maytags and Lady Kenmores. Frigidaire used the electronic sensor on the 1966-70 models, it looked a lot like the system used in the Lady Kenmore. In 1971, Frigidaire introduced another electronic smoisture sensor on the Custom Imperial model but it was different from the earlier one and it did use a timer (it was just used in 1971-72).
Note that the letters for the pushbuttons on the 1966 model aren't all capital letters like those on the 1965 and the dispenser door has different lettering, all centered.
The 1965 and 1966 Custom Imperial washers haven't changed much but the fonts/lettering for the pushbuttons also changed and the color patterns for the control panels changed too. In 1966, if you had a white machine, the control panel was gray instead of green as in 1965. Canadian machines continued with this configuration until 1970. The 1967 panel was red/white (I've never seen one of those) but kept using the 1966 round dial and pushbuttons and the 1968-70 models had a black/silver panel like the US "N" models but still had the round dial, and timed-fill for the washer.
The 1965 dryer doesn't have a start button. The models with the electronic control started to use one in 1966 (necessary because they don't have a timer that goes to "off" at the end of the cycle) and in 1967, all models had a start button.
The electronic control was introduced in 1966 on the DCIK, DCIFK, DCIAK and on the Canadian DJFK.
Delicate is placed between regular and heavy/bulky on all Frigidaire dryers that have an automatic mode except those with the electronic sensor (that's also true for the 1-18 models). The reason for that is that it cycles at a lower temperature on Delicate and the timer needs to be set to a longer time on that mode.
Here's a picture of John's (combo52) 1966 DCIAK with an electronic control. It has a non-translucent aluminum panel but still has fluorescent lighting for the dial and below the panel. The fonts are the same as those on the DCIK/DCIFK picture that you sent. It has a green panel like my 1965 because it's turquoise, otherwise, it would be gray.
