carcachute
Hi folks,
I think this is a long shot, but I'm at wit's end with my Samsung VRT front loader, model WF409. I've had it about five years and replaced the drum support and bearings last year. This washer used to complete the spin cycle in the estimated time of about 10 minutes. It started by balancing the load, then spinning to a low speed of about 100 RPM. Then it would attempt to accelerate through the resonance of the drum and suspension which is about 300-400 RPM, and would rebalance the load if too much vibration occurred at the resonance speed. Otherwise it would accelerate to about 400-500 RPM, pulse the drain pump to remove water for 10-20 seconds, and gradually accelerate to the final spin speed.
Lately, it's been sitting at that 400-500 RPM speed for as much as TEN MINUTES before accelerating to the final spin speed. It given the drain pump short pulses throughout this time. Drum rotation is smooth at that speed, too, so it doesn't seem to be a vibration issue. The drain pump is strong and I've cleaned the strainer twice. I even tried adjusting the water level sensor to make it think the level has dropped, in case it is erroneously sensing water in the drum, but that didn't change anything. The chassis is leveled properly to the floor and isn't shaking.
Any thoughts on what could be causing the firmware to hold the spin at half speed for ten additional minutes multiple times per cycle? I'm out of ideas!
