Samsung PowerFoam/EcoBubble
mralex
Jul 26, 2017
250
London, UK
So, Samsung is advertising better stain removal and better results at lower washing temperatures with their PowerFoam (for US) and EcoBubble (Europe and probably the rest of the world)
It creates a foam before the water has submerged the clothes with water (looks pretty much like something that usually would cause a suds lock). Since I grew up with the "foam doesn't mean cleaner clothes" concept I'm wondering why..?
What's everyone's thoughts on this?
http://https//www.youtube.com/watch?v=bvlq5oGmAMo
The idea was that the foam would mean disolved detergent and quicker saturation.
In theory, that's a sond concept.
They used a recirculation pump designed to mix water and detergent and added distribution tumbles.
However they didn't use the recirculation pump in the more logical and effective way of spraying the clothes.
It helped, but wasn't "the thing".
Now, Hotpoint with their "Direct Injection" tehnology basicly copied that. Electrolux took the whole thing one step further by using 3 pumps in total (drain, recirculation, mixing), which appears to work really well.
See here:
AEG Lavamat 8000
That recirculation jet looks decidedly weak.
Why don't manufacturers use decent strength pumps?
I wonder what the wash results and time saving would be if manufacturers fitted a dishwasher recirculating pump to washing machines...?
I currently...
Have a Samsung eco bubble machine.
This is my second one (the first one - the top of the range 12kg one with a colour screen; broke in 7 months).
The bubble thing is a gimmick in my opinion. Yes the Sasmungs clean very well (but so did my LG steam washer).
One thing though, living in a very soft water area like I do, I have to be VERY judicious with detergent dosage (as on this eco bubble I have, unlike the first one I had, you can't turn the eco bubble function off).
I like Panasonic's system: dump some water anf detergent into thw outer tub, spin the drum - foam and mostly dissolved detergent. The disadvantage, however, is that Panasonic has to use a motorized sump valve to prevent detergent from being pushed into the drain pump area.
Some manufacturers premix detergent with water and spray that onto the clothes (TOL Whirlpool US and Panasonic in Asia, for example).
Panasonic
The motorised sump valve was only used on the Chinese made, top-end Panasonics.
I'm sure that the Vestel (Turkey) Panasonics had an open sump.
The Gorenje (Slovenia) Panasonics certainly have an open sump. The way they operate is to flush the detergent from the drawer, to the tub, whilst a long continuous tumble takes place, water filling all the time. When the water level is achieved, a distribution speed tumble allows the detergent to be mixed. Normal tumbles back and forth for several minutes. After a short time, the recirculation pump activates for 30 seconds, with normal tumbling. Then it goes back to normal tumbling alone. This pattern repeats a few times, whilst the water is cold.
When temperature is reached (30 or 40 deg C), the recirculation pump activates again a couple more times, but in this case the pump stays on for a couple of minutes at a time.
The recirculation pump appears not to activate with 60 deg temps.
Foam
Personally, I am not a fan of foam generation - I think it is detrimental to the wash action.
I do like the concept of mixing the detergent in the tub though. Whether the detergent foams up or not, largely depends upon the type of detergent and manufacturer.
I've found ACDO and Daz '65 Yrs' powders, and 2017 Aldi Almat tablets to be low foaming.
Lidl's Formil powder is quite foamy, along with Tesco Bio tablets, and Aldi's 2015 Almat tablets.
I've found Surf 'White' liquid to be hellishly sudsy even with a spot of the stuff.
Ariel liquid and Persil liquid seem to be less sudsy.
There is something called "Rosalie's Zero Suds" and I heard it works quite well. I don't know how much it costs, but it must work well. I don't use a lot of detergent in my Maytag, but if something is heavily soiled, I use a little more, but not much. Sometimes there will be a lot of suds at the beginning of the wash cycle, but at the end before the first spin, all of the suds will be gone (the soil in clothes can eat up the suds)
