Sanyo Picture Thread.
No more wire hangers!
Rear view.
GE had them build it with a cold --AND A HOT-- fill, unlike Japanese machines. Also has a water-temperature selection knob, and a water-level control.
Timer was "Americanized" for the standard three cycles(programmes): Normal, Permanent Ppess and Gentle.
The Japanese verison tens to have "Normal" (with two deep rinses). "Economy" (with one deep rinse) and a manual cycle of "Wash" or maybe "Soak" only.
GE COMPACT WASHER
These are fun little machines I have had many over the years and worked on hundreds of them for others. First these are not made by Sanyo they look similar, but the GEs and HPs sold in the US are Hitachi built nothing is interchangeable with Sanyo machines. The first GEs had porcelain inner and outer tubs, the second generation like you have Steve had a plastic outer tub and a porcelain inner tub and the last GEs had plastic inner & outer tubs.
Hi Toggleswitch,
Great to see your action shots of the GE but it is definately made by Hitachi. Got heaps of Hitachi pictures saved which I will post soon on a new thread for all to compare :)
Also, most of the Japanese brands used porcelain tubs in the 70's, it seems to be about 79/80 that they became plastic tubs. Despite their lightweight construction, these little machines really do seem to last forever!
Sanyo Jet action.
This machine is from the 90's I know but thought I would keep it in this thread. These machines were sold here till about 2000 then they disappeared from the Australian market.
6kg Sanyo. This machine was somewhat larger and didn't sell in the same quantities as the smaller machines.
Hope you have enjoyed all the Sanyos. I should post the pictures I have of Hitachi and National/Panasonic machines sometime soon.
hey guys
i had a 70's Hitachi for a few years when last living out of home.
Was a great machine, bit 'tangle happy' but didn't miss a beat even tho it was old when i got it.
Video is below, there are also more videos of it at the link below.
Enjoy.
Matt
<object width="480" height="385"><param name="movie" value=""></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Sanyo and Hitachi
I know Steve, I also thought these machines were Sanyo built, they look almost spot on. I still sometimes slip up and call them Sanyos even though I know they're Hitachi. Good machines, the one that you've got is a slightly newer model than mine which is the original version under the Hotpoint nameplate. Your machine is called the "Convertible" because of the hot water valve and temp selection and is the higher model. This series uses a more familiar GE style control panel with appropriate knobs. There is a lower model with only one fill valve and just a water level switch, which to me makes more sense for a portable like this. They made stacking kits for these and they could be connected stationary with the dryer overhead for cramped spaces, I have a portable Lady Kenmore washer that's like that, either mobile or like a baby full size. The blue impeller is a lot more aggresive than the 5-spoke black impeller of the previous model. The blue impeller machine is sort of something I'm on the look out for as I had a harvest gold set when I was a kid and I really liked it. Anyway great little machine, is that the one that you got from Martin?
-Tim
