Hey Rick,
There are three suspension rods on this machine - there just hiding. One is under the timer, then the front right side, the the last is hiding under the snubber. The pic below has the tub hardware still removed - it is easier to see the suspension.
I know the gasket in the cap is still nice and flexible, but I haven't checked block yet for wear - I'll make sure to do that soon.
Askomiele: the snubber is a part of the suspension that holds the wash assembly in place. It is a piece of hardened rubber (on this machine), and when the tub shakes during spin, it helps reduce the amount of vibration by keeping the lateral movement on a single plane. Hope this helps.
Jon: no problem, pics I can do! Whatever happened to that AMP anyway?
Robert: the machine came out of a basement in the neighborhood around St. Thomas University. Nice homes around there!
Eugene: you had asked a while back - and yes, this machine is quite 'wide'! It would be the standard 27 inches, but it just looks like a tank, and sure feels like it too when you are moving it! The off balance is all mechanical, and I don't think this will trip the buzzer. It would take one hell of a swinging basket to hit that lever though!
