MT 575 Normal Options Selected / SQ TC5 Normal HD
MT 575
To the best of my knowledge, selecting any of the options including presoak (full tub presoak that turns into full tub wash/full tub rinse), extra rinse (full tub wash/2 full tub rinses), or presoak/extra rinse (full tub prewash that turns into full tub wash/2 full tub rinses) essentially turns the Normal "Eco" cycle into a full tub fill with full tub rinse(s)depending on options chosen. The temperature can also be controlled too. It becomes another option for a main cycle. However, with no options selected, the temperature seems to fixed to a cool wash.
I have not found any way to always be able to control the temp for the Normal cycle other than to run a Y adapter with hot and cold to the cold inlet valve and use the washer outlet boxes to control the temperature. (Most Y adapters with levers I have seen are designed for outdoor and cold water use only.) Relocating the ATC sensor only (and using the wash temp controls to manually control wash temp) seems to work during the winter when the air temp of that add-on room is slightly cooler than the rest of the house, which would be less than 65 degrees F? This would make sense since I think the ATC would activate and continue to activate the hot water valve if the wash temp is below this (and it will be since it is sensing air temp) even for the Normal cycle.
Being a little techy, I have combed through the manuals and posts I could find trying to look for jumpers, switches, etc. that would disable the ATC or energy-saving features or and have not found any yet...
The Powerwash may be a tap hot wash
. I am going to test this some more.
TC5
What I thought was unique about the TC5's Normal, is that selecting Heavy Duty turns it into a super cycle with a longer wash where the water temperature can be controlled. I did not watch it again, but it looks like (in the parts I watched again) it still has the spray rinse. However, the spray rinse does not *seem* to wet down the clothes effectively as the MTs.
Overall win for TC5, though, on this point due to temp control options and super cycle with HD.
Link to YT video referred to is below.
