I have an older sears kenmore dryer, Model 110.6957702w10. Everything appears operative except for that it does not heat up. The ignitor does cycle repeatedly but gas does not appear to flow. From all I have read, I suspect that the valve coils may be defective. Can anyone advise me on how to troubleshoot this problem. I have put an ohm meter on the thermostat(s) in the duct heater and blower housing and there is continuity in both. Next to the blower thermostat there is a rod shaped sensor that is connected by bare wire to the modulator(?) on the gas valve surface nearest the front of the machine. I am unsure how to test it. My next step is to remove the gas valve(part number 340710)from the machine. I need some advice about how to proceed after that point. Some guidance would be very much appreciated. I have attached a photo of the valve to this post. Thank you in advance.
