Sears Oasis-Have a look
WP has already announced their version
WP has already announced their version of the Oasis, called Cabrio. I have seen no information that would explain the differences between the KM and WP versions.
Cabrio?
Is it a convertible or a Mexican goat?
Well, if it enters my house it will wash topless.
They should call their current DD machines "CABRIO" because they eat whatever you put in them.
Agitator and Disk?
Seems there are two different washing technique in Oasis.
Agitator and Disk.
Why make two types?
How would they compare?
Windows: Sounds like someone at Sears is hanging out here:-) Or they saw the trend in Mexico & Brazil and thought it would be cool to do here.
Something on the website referred to "reverse rollover action." Does that mean up in the center and down at the circumference of the tub? How does it manage to do that?
Does Sears ever do sales demos where they would have these things in operation so one could observe?
Designgeek, I am totally concurred with you. How could these Oasis manage to do "reverse roller action"?
From the construction of these Oasis, the disk and agitator action will have a similar rollover action like a conventional agitator.
It seems that Oasis does not know what they write.
Concerning 'reverse rollover': I think they mean the impeller pulls (or rolls) the clothes over in first one direction, then it reverses and pulls them over the other way.
I don't see how they could do a 'center-to-the-outside' rollover unless those holes in the impeller somehow shoot water straight up with the force of a geyser, in which case I suppose it would be possible...theoretically.
Apparently nobody else has yet checked the details on that flash animation linked up in the first post. :-)
Reverse rollover means exactly what it says, according to the descriptions I've read. Clothes move UP the middle of the basket and DOWN the sides. I imagine that refers to the non-agitator models. Will be an interesting action to see. Being as the agitator is a corkscrew design, that model likely has a traditional up-the-sides-and-down-the-middle rollover ... unless the corkscrew also functions 'backwards.'
By the way, per the parts diagrams, the basket drive "clutch" is exactly the same as on my F&P GWL08 and IWL12, which means the basket floats upward when the machine fills to disengage from the drive, and settles back down to re-engage for spin .. which also means neutral drain.
Oasis has NO reverse rollover action?
One "Oasis user" in another laundry wrote:
"The load is moved from the outside toward the middle with items coming up in the center and down on the outside edges."
It sounds that it is a "reverse rollover action" which is opposed to a conventional TL-agitator. But have great doubt about this "user" accuracy.
From the parts diagram, there are two pumps: one for drain and the other for recirculation/spray. There is no sign of such powerful jet action from any other pump.
Would not believe that Oasis has "reverse rollover action" unless it is proved by sight.
Agitator and Disk?
Only my opinion! I think WP knows that many people still want a familiar agitator washing their clothes instead of a FL. Fl's need too many specifics to get what a TL machine can do in 40-45 minutes. I am not anti FL in any way...cool splash action. I applaud WP for doing what they doing.
Guys really who is left?
Two definitions of reverse rollover ?
We have two definitions of "reverse rollover".
Does Oasis use the definition of frigilux or others?
Need jasonl to confirm?
This is certainly a handsome w/d set; I want to find out if there is going to be a wrinkling/tangling issue with it, as there was with the Calypso and the Maytag TL Neptune.
If this machine gets good reports from both home users and Consumer Reports, it may be the first TL'er to tempt me away from my beloved FL format... Love that moon-roof lid on the washer.
My only other comment is this: Should their descriptive have jumped from 'king size' capacity straight to 'canyon' capacity? Maybe they should have left room for enlargement by saying this first-issue model had 'crater' capacity, LOL! It's hard to go any larger than Canyon Capacity.
Nah, just the American tendency toward bigger-is-better, which works up to a point. I suppose the next size up from Canyon would be called an Oceanic:-)
Here's another speculation on what they might mean by "reverse rollover." Perhaps if the water level is just right (i.e. less water than a conventional TL, which could be the water conservation aspect they're promoting), the disc causes the entire mass of water & clothes to move in a circle that coincides with the axis of the disc? That would require a slow long stroke with a brief pause between reversals. The turnover would be less rapid than with conventional agitation, and much of the cleaning would be done at the bottom of the tub where the water currents were most vigorous. Could be effective, but also potentially very splashy.
BTW, I did check out the link above. -> About Oasis -> Cleans better: shows a slow-motion animation or series of sill pics with one white item among a bunch of dark items, but I still can't figure out exactly what's going on.
And now that I think of it, interesting that they have a little *boy* looking into the machine: breaking down the old stereotypes about girls and housework, and/or maybe playing off the idea of boys being into interesting mechanical stuff (i.e. implied: this is so mechanically innovative that boys find it interesting). The same little boy turns up in another picture, sitting on the clear lid while mom is picking up a laundry basket. (Implied: Yes, the clear lid is strong, look, your kid can sit on it without breaking it.) In fact there's yet another shot of the same kid looking into the dryer: he's got a soccer ball in one hand, and his sneakers are apparently sitting on a removable shelf that's been put in the dryer to dry them. (implied: but this boy's not an indoor-kid, see, he plays outdoor sports!)
The next marketing ploy could be "bottomless pit" capacity. Ha! All of these adjectives really mean nothing....ex large, super, king-size...what does that tell you? All the manufacturers should just list tub size. Seems like only the front loaders do that.
