The gravity drain Kitchenaids were wired such that if you opened the door during one of the "washing" periods it cut the power to everything EXCEPT the signal light and the drain solenoid. Because, if you think about it, since the drain solenoid was energized to keep water IN, if you opened the door while it was washing and it cut power to the whole machine the water would drain OUT. If, however you advanced the timer dial past a washing period, the drain solenoid would not be energized through the timer anyways if you opened the door.
